Crank Trigger Pattern & Other questions
Old Jun 24, 2022 | 08:55 AM
ypkx's Avatar
ypkx
Default Crank Trigger Pattern & Other questions
Hello
I didn't want to spam the forum with multiple threads and I know for a fact that this wont be the first or last thread I'll make now that I am at the final stages of my build.
Quite techy questions...
  1. Would anyone know what the crank trigger wheel pattern is for an IS250 2011? Auto, if that makes any difference. I need this to trick the Lexus ECU.
  2. I no longer have the neutral safety switch - is there a way to trick the IS250 into thinking its in neutral without buying an NSS? I know SC300s and older gen IS200/300s can..
Thanks
Old Jun 24, 2022 | 12:18 PM
2013FSport's Avatar
2013FSport
Originally Posted by ypkx
Hello
Thanks
See pictures:
Part2:
I'm guessing new engine to this car will not be using the engine control ecu is that correct? If it IS, Permanently engaged in neutral will throw codes once it starts moving.
Some details on the actual plane perhaps? It sounds like you need a black box to mimic a bunch of missing inputs.
Old Jun 25, 2022 | 06:18 AM
ypkx's Avatar
ypkx
Originally Posted by 2013FSport
See pictures:
Part2:
Hello mate,
Just had a look, looks like 32-2, thanks! Somewhere we found info online suggesting it was 36-2
No, so new engine has a standalone but we are trying to wire the original 'push to start' button to work with new engine. We have a trigger wire ready to wire up.
The codes isn't the issue, we need to and want to understand if the neutral safety switch is stopping it from cranking from the button.
Thanks!
Old Jun 25, 2022 | 03:57 PM
2013FSport's Avatar
2013FSport
Hello mate,
Thanks!
So this was an automatic I'll assume but honestly it doesn't matter. Pull up the schematic and look. I mean, if you're this deep, you must have that, yes?
Old Sep 3, 2022 | 07:42 AM
ypkx's Avatar
ypkx
Appreciate the help buddy, thank you.
Basically, the information isn't free and is a nightmare getting ahold of here in the UK.
We've got everything working now with a lot of help from some US buddies.
Now back to the trigger pattern for rpm.
Shaq32
Aug 10, 2017 12:46 AM
romchrari
Wheels, Tires & Brakes Forum
May 16, 2014 04:11 PM
mansito
Aug 5, 2013 07:12 AM
jordan9923
Florida Lexus Club
Aug 8, 2012 05:33 AM
