Automatic Transmission not engaging gears
Old Jun 4, 2022 | 07:09 AM
tauhier's Avatar
tauhier
4th Gear
Default Automatic Transmission not engaging gears
Hi guys, please advise, my transmission is still jot engaging, when I start my car and change from P to R or N or D it shifts but does not engage, and when I go back to P it makes a grinding sound, I removed the transmission pan and when I switch the ignition on the solenoids makes a buzzing sound, but when I shift to sport mode and downshift to 1st, the buzz stops, but as soon as I either shift up or selects D or N or P the it buzzes again and makes a grinding sound when changing from R to P.
I tested each solenoid individually and it all works seems like car is still in a gear but not sure how to decifer from here.
Old Sep 1, 2022 | 08:42 AM
BXIS250's Avatar
BXIS250
You removed the oil pan, and then the gears wouldn't change, or?
Either way, a solenoid shouldn't buzz. They click, and that's it.
Did you follow the factory service manual testing precedure?
TRENTIMUS
GS - 1st Gen (1993-1997)
Mar 13, 2015 10:18 AM
josephx66
Dec 12, 2011 12:55 PM
IS350jet
Apr 24, 2008 12:16 PM
