Replacing the brake fluid cap??
Old Mar 8, 2022 | 10:08 PM
ncatona's Avatar
ncatona
Default Replacing the brake fluid cap??
Has anyone ever replaced the brake fluid cap itself as part of maintenance? Wouldn’t those rubber things deteriorate after sometime?
I am going to get my fluid flushed this week and it’s the first time since I’ve owned the car :/ definitely the “neglected” part right now since the color is green.
Old Mar 9, 2022 | 12:13 PM
2013FSport's Avatar
2013FSport
Yikes... Green fluid usually implies moisture is in the system as it's breaking the fluid down.
You might consider an MC replacement as it's not worth dying for. As for the cap, it likely just needs cleaned.
Old Mar 10, 2022 | 06:53 PM
ncatona's Avatar
ncatona
Fluid is changed and the brakes are definitely smoother, pedals engaging with more control now.
Old Mar 11, 2022 | 01:36 PM
MikeFig82's Avatar
MikeFig82
Sounds good. Just keep monitoring the fluid color for some time.
Old Mar 12, 2022 | 11:05 PM
ncatona's Avatar
ncatona
After driving it more, I have to press the brake pedal less further down for engagement and it’s much more linear and controllable because before I’d have rough stops and lurch forward. Go flush yo brake fluid!!!!
Old Mar 14, 2022 | 12:16 PM
2013FSport's Avatar
2013FSport
Ya, every two to three years as it absorbs moisture. Come to think of it, I'm guessing mine is due since caliper paint and rebuild!
emdcksn
ES - 7th Gen (2019-2025)
15
Aug 8, 2021 08:28 PM
robd88
Jul 6, 2019 04:19 PM
RageRacerM
Suspension and Brakes
Nov 20, 2018 08:05 AM
johnnyreno
Jul 23, 2014 09:10 PM
