Camshaft Position Sensor Circuit
Old Jan 22, 2022 | 08:53 PM
2FiddyIS's Avatar
2FiddyIS
Default Camshaft Position Sensor Circuit
CEL and VSC light on, code P0345 came on after changing alternator. Accidentally pulled the wire out of connector,ordered a new one through amazon. CEL and VSC light is still on after new connector installed.Car runs and drives fine but some loss off acceleration.
Old Jan 23, 2022 | 08:51 AM
MikeFig82's Avatar
MikeFig82
On the scan tool does the code show as permanent? This happens if the obd code triggers while car is on. Meaning if you disconnect a critical sensor, and try to plug it back in while car is idling. If that's the case the light will go off by itself after a few cycles. It has to do with trying to cheat on emissions if im not mistaken.
Old Jan 23, 2022 | 09:52 AM
2FiddyIS's Avatar
2FiddyIS
Yes, same code is stored and pending. I erase it but comes back right away
Old Jan 23, 2022 | 12:35 PM
MikeFig82's Avatar
MikeFig82
How long did you let it sit before resetting?
If you keep resetting it won't reach OBDII emissions readiness. Which takes about 100 miles if mixed driving. While then you must let the engine complete 2-3 drive cycles.
If the light still won't go off on its own. Then some other issue is still going on related to the code.
https://repairpal.com/how-to-perform...ic-drive-cycle
Old Jan 23, 2022 | 02:43 PM
2FiddyIS's Avatar
2FiddyIS
I usually didn’t let it sit long between resets, I’ll give it try
Old Jan 24, 2022 | 10:20 AM
gmr76's Avatar
gmr76
I just did this - do you have the part number for the plug you ordered?
Old Jan 24, 2022 | 11:41 AM
2FiddyIS's Avatar
2FiddyIS
This one seems to work for me.
Amazon Amazon
smmothsail
Dec 5, 2022 09:55 AM
Mickyskinn
Suspension and Brakes
Feb 18, 2021 07:19 PM
jocru28
May 11, 2020 11:07 AM
E062266
14
Dec 6, 2018 08:33 AM
nwchopper
IS - 1st Gen (2001-2005)
Sep 10, 2013 04:56 AM
