Help with ABS light
Old Jan 9, 2022 | 08:22 AM
ameer90's Avatar
ameer90
Default Help with ABS light
Hello,
last week and after the rain. The ABS warning light and Traction control warning light came on.
I scan the codes and got C1405 + C1413 which are both related to the right front speed sensor.
but when I see the live data, all sensors are working probably.
some times the
ABS light appear in conjunction to check headlight system warning.
any one knows how can I solve the problem?
Old Jan 10, 2022 | 04:57 AM
ameer90's Avatar
ameer90
Update
today While driving the ABS LIGHT came on and I captured the screen. It’s 90% sensor problem because sometimes it works and sometimes does not.
I will try to replace the sensor. But one question came to my mind. Why I got check headlight system on my dashboard in the same time the ABS Light came on ?
Old Jan 10, 2022 | 06:45 AM
alvtrex's Avatar
alvtrex
9th Gear
IIRC, there are either 2 different sensors in the unit or 2 modes in the sensor: one for low speed and one for high speed.
Clearly, it's your high speed that is defective.
Changing the unit will solve your problem.
Old Jan 10, 2022 | 07:00 AM
ameer90's Avatar
ameer90
Thanks for your reply. Could you please tell me what should I replace in order to solve the problem?
I think the ABS sensor come with hub bearing as a one part.
Old Jan 10, 2022 | 08:02 AM
alvtrex's Avatar
alvtrex
9th Gear
In my case, it was a rear sensor and it was available by itself, so it was easy to replace and pretty cheap. I have an AWD.
For the front, I'm not too sure, sorry. I believe you need to replace the hub but don't quote me on that.
It may also vary depending if your car is AWD or RWD.
Old Nov 16, 2022 | 06:39 AM
Winters's Avatar
Winters
5th Gear
Hey! Were you able to fix the issue? I had the same codes but for front left on a RWD (ISC 2014). I changed the hub that comes with the sensor and I am still getting the abs light and traction control light coming up. Not sure what to do at this point.
I am hoping there is not a short in the circuit and I think that might be my next step will be to test the circuit to see if I have the correct voltage or if there is a short...
Anyone have any other leads as to what could be causing this?
Thanks!
tom8757
Dec 15, 2012 05:51 PM
dlb993
RX - 1st Gen (1999-2003)
Feb 1, 2010 06:20 PM
sik96ls400
Dec 4, 2009 03:19 PM
felixcat
Jul 6, 2006 01:09 PM
illson_2k
May 30, 2003 01:17 AM
