Aux malfunction HELP!!!!!
Old Sep 29, 2021 | 11:13 PM
Terrilll's Avatar
Terrilll
Default Aux malfunction HELP!!!!!
My Aux port only works when I have something plug into the power supply at the same time draining power. What can be the issuse?
Old Sep 30, 2021 | 01:52 PM
ExiledWolf84's Avatar
ExiledWolf84
It only works when something is plugged in? If so, that's how it supposed to work, unless you can give further details as to what else is happening.
Old Sep 30, 2021 | 02:05 PM
Terrilll's Avatar
Terrilll
the aux only works of something is plug into the cigarette lighter while the aux cord is plugged in it didn’t do that before
Old Oct 1, 2021 | 05:21 PM
2013FSport's Avatar
2013FSport
Please confirm the powered device is not also the Aux input device. If so, try a different input device into Aux port. Tablet or something...
If some control board for the AUX input lost power, it could be that feedback through another circuit (Accessory +12), makes a connection that wouldn't be there when the port is empty.
Check all the fuses under the dash (both kick panels) and under the hood. The owners manual provides a brief description of what some do. I suspect it's 10A or less.
Old Oct 2, 2021 | 01:37 AM
Auximenes's Avatar
Auximenes
Do you mean that it will only work if the playback device is getting power from the cigarette lighter supply?
Old Oct 2, 2021 | 07:26 AM
Terrilll's Avatar
Terrilll
Default Fuses checked
all fuses have been checked everything is working properly also changed out the AUX port with 2 different ones still the same issue it only works while I have something plugged into 12v power supply
Brianlt95
RC - 1st Gen (2015-present)
Oct 5, 2016 06:28 PM
clintdaddy
Mar 17, 2016 05:33 PM
GGPGregis3
Jan 18, 2015 06:54 PM
HALLELUJAH
Aug 19, 2011 09:50 AM
Libra14
Jun 20, 2011 12:36 PM
