is250 slow engine startup
i have done a search and see alot of post saying it probably carbon build up on the IAC but my problem start after i was on vacation for 3 weeks and the car sat
basically when i went to start it it was very slow to start up but after a few seconds it came back to normal, drove the car around the parking lot, no issues, maybe a little bog when shifting, not much just in the very beginning
next day same thing, this time ran a few errands in the car, everytime after the slow start up when the car was already warmed up if i shut it off and turned it back on it started fine, would leave it parked for a hour or so while at the supermarket came back and it was fine, no jumping rpms or anything like that while driving, then when i would go home, next day same thing, but only the the first start up. no check engine light
so its been three days since i got back from vacation and still does it on the first start up of the day
any thoughts?
any thoughts?
From what you've said so far, you really should get the battery and alternator tested. Usually, if it starts up just fine when the car is warm, and only starts slow on a cold start, usually one of the two are the culprit. How old is the battery?
any thoughts?
any thoughts?
Both of the posts ^^^ above ^^^ hold the answer. Weak battery from possibly bad connections or if more than 4 years (3 in hot climates), just replace the battery.
YaYAReAGs3
GS - 1st Gen (1993-1997)
Sep 5, 2004 12:43 PM
