Light pinging with hard acceleration: after spark plug change
Old Aug 9, 2021 | 04:18 PM
  #31
2013FSport's Avatar
2013FSport
Originally Posted by Dealarr
Is there absolutely no way to factory reset other than Techstream? Sigh.
I suspect some tools are capable. Like resetting the CEL. You have to check the tool.
Originally Posted by Leederosa
@2013FSport Sadly, my app doesn't have the KCLV data. Is there anything else I can use?
The OBD Fusion App $5.00 and Toyota Lexus Scion PID pack $10, should do it.
Old Aug 10, 2021 | 12:55 PM
  #32
Leederosa's Avatar
Leederosa
Of course, I spoke too soon. So there's still intermittent pinging, but definitely not as frequent and not as loud. Still looking for a window to get the O2 sensor done.
The mystery continues...
Old Aug 10, 2021 | 01:31 PM
  #33
2013FSport's Avatar
2013FSport
It's not uncommon that all apps dont do everything. You'd have cell on if the sensors were even remotely incapable of reporting data. I don't think that is your problem.
Also, don't leave seafoam in the crankcase too long. Read the label for max duration.
Are you absolutely certain the sound is detonation?
Old Aug 11, 2021 | 11:59 AM
  #34
Dealarr's Avatar
Dealarr
Before you get it done can you just check to see if it's still connected. Both of them. I am not asking you to change them. If they are still on there but disconnected. Your afr sensors are not reporting voltage, your post cats ones are, and they are displaying the correct fluctuations, 0.1v - 0.95v usually.
Old Aug 16, 2021 | 12:43 PM
  #35
Leederosa's Avatar
Leederosa
So I finally got back into another shop (a legit Toyota specialist), they hooked up their OBDII and found that the O2 sensors are all working properly. Apparently, my app wasn't reading properly for sensor 1. He took it for a spin and believes the pinging is related to carbon buildup.
He said it was probably just a coincidence that it started to happen after the spark plug change. Although, I'm wondering if the OEM sparkplugs that are in it now (Denso) run hotter than the NGKs that were in it before the spark plug change? Could a temperature difference cause pinging? Regardless, I'm inclined to agree that it's a carbon issue.
Old Jul 31, 2023 | 07:10 AM
  #36
Idkyet2is's Avatar
Idkyet2is
Did you ever find out what was causing your pinging?
resharoo
Jul 21, 2015 09:49 AM
isam250
Dec 23, 2013 11:32 AM
xDunksNjsX
17
May 31, 2013 01:16 AM
ColeTrickl
Apr 28, 2010 09:38 PM
MidTownMan
Apr 3, 2010 11:10 PM
