wheel spacers
Old Apr 23, 2021 | 12:49 PM
DdotSdot's Avatar
DdotSdot
Default wheel spacers
I am running 18x8.5 +35 wheels in front and 18x9.5 +35 wheels in the rear and I was wondering what were my best options for wheel spacers. If you have a similar setup with spacers I would love to see a picture and know what size spacer you have and if there are any other modifications that need to be done. thank you.
Old Apr 23, 2021 | 08:31 PM
primavera's Avatar
primavera
With those specs your wheels are most likely flush with fenders. If you still want to use spacers you can determine the thickness by stacking few washers on studs.
Old Apr 24, 2021 | 12:30 AM
dunstopnow's Avatar
dunstopnow
I have stock 18's on with 25mm spacer in the rear. Rear set is 18x8.5 +45 I believe. Rear is flush
Old Apr 24, 2021 | 11:19 AM
DdotSdot's Avatar
DdotSdot
Thats a good trick thank you
Old Apr 24, 2021 | 11:20 AM
DdotSdot's Avatar
DdotSdot
Did you have to grind down the original studs for the spacer to fit?
Old Apr 24, 2021 | 03:33 PM
primavera's Avatar
primavera
If the wheel pockets are deep enough you don't have to cut the studs. Alternatively you can bore the wheel pockets a bit deeper which will have the same effect. What kind of spacers do you plan on using?
https://www.clublexus.com/forums/sus...l#post10869598
Old Apr 29, 2021 | 10:10 AM
DdotSdot's Avatar
DdotSdot
I planned on getting 25mm enkei spacers. I know that its a good brand and I know that spacer will fit.
Old Apr 29, 2021 | 11:03 AM
2013FSport's Avatar
2013FSport
Honestly you can open this up to about anything you have lying around. Washers are great if you have them. I had some wood like a paint stir stick that just happened to measure 5mm thick. I cut them down, laid them across 2 studs and set the wheel on, screw a couple nuts on. Then add the same from bottom going through the wheel and snug the nuts.
It was quick, easy, and cheap to try 5, 10, 15mm spacings.
gsfdream
GS F (2016-present)
70
Jul 22, 2023 06:53 AM
Rock-a-Lex
Suspension and Brakes
19
Mar 28, 2008 05:16 PM
djl
Aug 23, 2004 04:49 AM
gs4to4
13
Aug 1, 2001 03:53 AM
sleepybobcat
RX - 1st Gen (1999-2003)
May 14, 2001 07:35 AM
