Vacuum leak, misfire
Hi guys. Over Christmas I parked my 2006 is350 in our garage, unfortunately somehow rats made a nest, they in the meantime chewed through my knock sensor harness, and broke 2 injectors.
I have now replaced the harness, injectors, and spark plugs, prior to this the car had no issues.
I have now put everything back together, and the car is not running right. I’ve had several different codes including, p1071, p1074, p300, p303, p305. I know what all these mean and used my scanner and did some research. I know these codes refer to vacuum leaks and misfires on cylinders 3&5. I changed out 2 of the new spark plugs to the old and cleared the misfire code and that is okay now. Upon start up the car revs to 2k rpm or higher, which is a little abnormal, the car won’t allow itself to rev under 1100rpm even while warm. Driving the car is normal until you attempt to come to a stop, when it is in 1st gear and slowing down the car will drop revs down to 500 and then go back up to the 1100 when you come to a complete stop.
I have sprayed in several locations around the plenum, throttle body, and hoses and I’m having a really hard time finding any leaking hoses. I’m hoping someone on here can offer me some insight on where else I could potentially look for leaks, or if anyone has any idea on what else it could be, thanks in advance.
mkivmattho
Jul 19, 2020 07:21 AM
ManuelFdz
Dec 31, 2017 06:58 AM
