Cracked Outer Water Jacket
Old Nov 17, 2020 | 09:41 AM
AMIRZA786's Avatar
AMIRZA786
Originally Posted by jusss2is
Any info on specific brand and how to do it? is it the same as the nowadays called “JBWeld” products? Should I be fine just leaving it alone? My biggest fear is it will crack enough to rupture inside the cylinder, fingers crossed I hope not.
Yes, JBWeld is the product that makes Liquid Weld. It would be better to get it welded by someone who does aluminum welding as earlier mentioned. We only used it to save the head (a new one was out of the question), which was cracked and too deep for the machinist to machine out. We filled the crack with Liquid Weld, let it dry over-night than he machined it down. Can't say if it worked long term as I sold the car a few months later. In your case if coolant is leaking into the oil, it's better to aluminum weld it
Old Nov 20, 2020 | 06:43 AM
Gville350's Avatar
Gville350
Personally, I'd Dremel out the crack slightly to get a good base from which to aluminum weld to. Then have someone weld that sucker up. Have them use welding/heat absorption paste around the crack to minimize heat transfer. Final results won't have to look pretty, just need to seal you up!
Good luck!
thetrevste
May 31, 2021 08:00 AM
JBison73
May 20, 2021 02:56 PM
digger08
IS F (2008-2014)
234
Jan 15, 2018 10:36 PM
Doc Yota
19
Jul 19, 2014 12:31 AM
wcoastls
17
Jul 15, 2011 04:17 AM
