Electrical problems
Old Oct 15, 2020 | 08:48 AM
Chris07100's Avatar
Chris07100
Default Electrical problems
Hi. I have a 2008 IS250 with about 150K. Unfortunately I've had to keep it in the sun in Las Vegas as my wife's 2014 RX350 (with 30K) is occupying the garage. I don't know if this is playing a factor.
I've recently run into some electrical problems that seemed at happen at once or within a few days,
1. Windshield washer fluid not working (but wipers do)
2 Tire sensor is stuck on even though tires are new and inflated properly
3. Touch screen started to become unresponsive.
Took it to my mechanic Freedom Automotive in Henderson, most honest guys I've met! highly recommend). He said it sounds like the controller but wants me to take it to Lexus for a $250 inspection to make sure what we're dealing with. I think I'm going to go ahead and do it but I'm in the market for a new (used one) anyway, so I don't know if I want to dump another $1,000 into a car only worth about $4,000 - $5,000.
The controller seems to sell used on Ebay for about $100 plus installation. The mechanic mentioned there may need to be a $200 programming fee at Lexus. So if this is the ONLY issue, it will be up there at around $1,000 give or take a couple of hundred bucks.
Has anyone experienced this before? I'm thinking to just replace the controller to see what happens and save the $260 inspection by Lexus. However, that might not be the wisest thing to do.
Thanks for your feedback!
Old Oct 15, 2020 | 08:49 AM
Chris07100's Avatar
Chris07100
I also have a sputtering problem but the mechanic says the engine is sound. When I'm at a red light the motor loses a bit of power on occasion. It's not something I can reproduce and just happens at random. I just had it tuned about 2 months ago so I'm wondering if this could be related to electronics/ sensors.
Old Oct 15, 2020 | 09:33 AM
AMIRZA786's Avatar
AMIRZA786
I don't know about the first issue, but the second issue could be carbon build-up. The IS250 has Direct Injection and due to the mileage you currently have that what it sounds like it could be. Another possibility is CAT starting to go bad
Old Oct 15, 2020 | 09:59 AM
IS250_6MT's Avatar
IS250_6MT
What controller is your mechanic suggesting to replace?
And it also sounds like rough idling may be because of the carbon build up as AMIRZA786 mentioned above.
Some additional info here and this article also includes a way that dealership uses to test for the misfire.
https://www.clublexus.com/how-tos/a/...mize-it-367282
1. Warm engine until temp gauge reads approximately in center between cold and hot.
2. Rev engine to 4,000 rpm for 30 seconds.
3. Immediately as you get to 30 seconds, run it up to 6,000 rpm very quickly and immediately release gas pedal.
4. Let it return to idle. If misfires are present, you will know by the unmistakable shaking or shuddering. You may not get misfires or codes the first time around, which is why dealers sometimes keep cars overnight to try what they described as a cold soak.
Old Oct 15, 2020 | 11:43 AM
RA030926's Avatar
RA030926
Buy this to fix navi
https://www.ebay.com/itm/NAVIGATION-...QAAOSwqU5ZwKjA
Old Oct 15, 2020 | 11:44 AM
RA030926's Avatar
RA030926
To fix windshield wiper, it seems like one if the Y piping under the hood insulation has broken. Just need to open it up and replace the part.
Old Oct 15, 2020 | 11:45 AM
RA030926's Avatar
RA030926
For tire sensors, hold down the middle button and see if it goes away.
Cp2295
Oct 17, 2020 10:01 PM
Marley19
NX - 1st Gen (2015-2021)
Jul 8, 2020 10:31 PM
aprilgirl
Mar 5, 2018 12:47 AM
15RC350F
Feb 24, 2015 06:13 PM
trystanu
Jul 1, 2005 04:37 PM
