245/40/18 Square on IS350?
Old Apr 13, 2020 | 12:34 PM
CR055's Avatar
CR055
Default 245/40/18 Square on IS350?
Will a 245/40/18 square setup with 18x8 +40mm work on an IS 350?
Old Apr 13, 2020 | 01:07 PM
ohiois350's Avatar
ohiois350
i tried the IS350 rear wheel with 255/40/18 with 50 mm offset and it fit fine but only have about 1 or 2 mm clearance for the tire not to touch the arm control, I think that specs work fine
Old Apr 13, 2020 | 02:00 PM
primavera's Avatar
primavera
https://www.clublexus.com/forums/is-...are-setup.html
Old Apr 13, 2020 | 03:34 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
I can't speak to 245/40R18 up front, though I'm sure others have tried it.
For myself I run a 245/40R17 square setup and have had no issues with rubbing or clearance. That said, I am on the factory sport suspension springs and so am not really lowered.
Jeff
Old Apr 13, 2020 | 04:07 PM
primavera's Avatar
primavera
Jeff
245/45R17 should work fine with the right offset.
In the next few days I'm gonna try ISF size tires 225/40R19 and 255/35R19. Several members installed ISF wheels and tires with success on their ISX50.
Old Apr 13, 2020 | 05:11 PM
CR055's Avatar
CR055
Jeff
I’m at stock height as well. I found these wheels on Marketplace for real cheap, just don’t know if they’ll fit or not.
cleethree
Nov 4, 2019 06:40 PM
njmurvin
Oct 22, 2008 05:04 PM
