How does a slipping auto transmission feel
I read a lot about people doing the drain and fill then after a while do another drain and fill and repeat few times. But if using a garage to do this, it's going to be very expensive compared to what the automatic transmission specialist are suggesting which is a fluid exchange. They say I need about 10L of new transmission fluid. Not sure exactly how they do the exchange of the full fluid. I can only imagine it's some kind of flushing that will flush the fluid out completely.
@firelikeiy are you suggesting I do the full fluid exchange or not? i'm a little confused
What are the risks of a full fluid change and if I do a full fluid change including filter etc, how many thousands of miles will it need doing again? It's a bit scary because i've read people saying that you can damage the transmission by doing a complete flush.
What are the risks of a full fluid change and if I do a full fluid change including filter etc, how many thousands of miles will it need doing again? It's a bit scary because i've read people saying that you can damage the transmission by doing a complete flush.Sorry, I wrote a reply and then actually read this thread. Yes, do a full fluid exchange. It sounds like your transmission is just starting to have issues. I think it will be alright doing the full flush.
I am about to have some parts installed at very well rated import shop & I am considering getting my transmission drained & filled on my 07 IS250. She doesn't run bad, she is just a little sluggish but I do believe she has carbon build up issues which may be contributing to sluggish acceleration.. When I go from park to reverse sometimes it will skip R & go straight to N but sometimes I feel like it could be my fault early in mornings when I'm barely awake haha. She idles at little weird sometimes too lately. Occasionally, I'll be at a red light & she'll start to idle up and down & then it almost feels like the car is bout to run out of gas & turn off as it starts to shake a little... I have not had anything transmission work done since I got the car @ 89K, now at 170K, so I imagine I am overdue for a change.. I am pretty young & learning everyday as I go, so definitely playing catch up on my maintenance. I will of course ask the shop but I value everyones opinion on here.
Yes, look into getting your trans fluid replaced BEFORE you encounter trans issues. Preventative maintenance FTW!
I come from an ISF, unfortunately mine has been slipping as well. did the level procedure and a fluid + filter change and still slipping at some points but does feel better. i recommend servicing it. no fluid is lifetime. bust of luck!
Had you ran low on fluid due to a leak OR was it just the original trans fluid that began to create the slipping issue? Hope the slipping completely goes away; many times when a trans starts slipping the internal parts glaze over from excessive heat/wear and no amount of fresh fluid can fix that.
I just bought the car at the end of September, so your guess is as good as mine about the life the transmission had. when i did the level set procedure the other night, fluid came out looking like it should. thats about all the info i have.
@Gville350 @2013FSport So I just got my 250 back today from having the transmission drained & filled &... The car feels funny. So like I said before, I wasn't sure there was any issues with my car before the flush. Upon receiving car from shop & driving it, I immediately noticed some "stiffness" I guess you could say. It feels like the car needs a bigger push to get up & going. I tried the sport mode using the my regular shifter (my - paddle shifter stopped working month after buying car, so dont use em) & sport mode definitely seems more responsive than before but still not how I think it should be working. What really worries me is the guy whom I spoke to at shop said he was very familiar with the toyota system since he has 2 toyota's himself but upon looking at the receipt he gave me, I immediately felt like I should check if he used the correct fluid. I found out he used " ENEOS ECO ATF FLUID" # WP-399571, I looked it up & saw that its "compatible with Japanese's vehicles but still... wouldn't it have a different viscosity or something that wouldn't mix correctly with the original toyota ATF fluid..? So I'm pretty worried & would like to know what you guys think. Thanks !
It's probably a better fluid. Toyota WS fluid is a synthetic blend whereas Eneos claims to be a full synthetic. Supposedly, Toyota WS fluid was created so that Toyota would have to pay less taxes for the vehicles they sell in the US due to its longer service interval. Exxon/mobil makes the fluid for Toyota.
Sorry, but I can relate to your words about it needing a bigger push. Can you elaborate?
@firelikeiy I do agree & see that ENEOS seems to be advertised as a better fluid but being at 170K miles, its pretty late in the game to start changing the type fluid the car uses I would think.. & they didnt change the filter, just a drain & fill to introduce new fluid.
@2013FSport After testing the car for a few days, the car is doing a little better but, for instance, usually, I can step on the gas/floor it & the car will immediately pick up & go. From 20 - 50 no problem, now... (ive tested this a few times) From a complete stop I floor it & the car pretty much goes nowhere.. it just slowly pushes itself & it takes like a minute or two to just hit 40's. Even from a 20 MPH roll, I floor it & again the car pretty much goes nowhere,no quick acceleration, no power at all.. if that better describes my situation. We are dealing with snow now in CO, so wont be doing any more tests till roads are clear, but I'll do my best to remember to record a test run when the weather clears up & post the video so you have a better understanding of what I am describing
@firelikeiy haha no, I made sure of that. I got the car back days before any snow arrived in CO, so no reason for snow mode to be on.
Slipping transmission = either your transmission is dying or you can still saving it by doing a last resort solenoid, pan filter and fluid replacement.
Can easily be avoided with regular transmission pan filter servicing.
What is your mileage. Is it worse when the transmission is still cold? or happens all the time? are you a careful driver or do you drive the thing hard? did it just start happening recently? does it only slip or behave strangely in specific gears?
Does the transmission filter have 1 or two O rings? When you replace the filter inside the transmission sump pan, lets say god forbid the rings fail or didnt seat correctly. Seeing as the filter is inside the transmission pan and then sealed up with the transmission pan gasket, you will never actually see if those rings fail and if the filter O rings leak. What will be the consequences of that? I get a bit paranoid about O rings and things that sit inside. The ones that you can check externally at least you have the peace of mind that you can visually inspect it.
