Cabin Temperature Sensor
Old Oct 26, 2020 | 11:46 AM
bez88hlb's Avatar
bez88hlb
Would a bad temperature sensor cause a motor blower not to turn on? Been having issues with my 2006 is250 the motor blower will not turn on, checked fuses, new motor blower and still no luck...was told to maybe check temp sensor or ac amplifier, would anyone happen to know if these will cause a blower to not turn on?
Old Oct 26, 2020 | 11:48 AM
bez88hlb's Avatar
bez88hlb
Originally Posted by 2013FSport
I take that back. Although it hovered at cabin temperature, it is not the cabin sensor. Behaves a lot like the cabin. It os not the seat temperature either unless it it was plugged into me bum at 98.8... Top left...
Disregard post...
Would a bad temperature sensor cause a motor blower not to turn on? Been having issues with my 2006 is250 the motor blower will not turn on, checked fuses and relay, new motor blower and still no luck...was told to maybe check temp sensor or ac amplifier, would anyone happen to know if these will cause a blower to not turn on?
Old Oct 26, 2020 | 11:49 AM
bez88hlb's Avatar
bez88hlb
Originally Posted by MikeFig82
So your saying you can't control fan speed? In the older gens Lexus line up they had a blower resistor the size of a cigarette pack. It controlled the fan speeds on the blower. When it went bad fan only blew on high speed, but you had to ground the blower to the chassis to bypass it.
The 2nd Gen IS has a AC amplifier. It controls pretty much the same as the resistor.
Look up threads on AC amplifier. If you find the hose yields the same results.
Old Oct 26, 2020 | 12:15 PM
MikeFig82's Avatar
MikeFig82
It depends on how the manufacturer designed it. On the Toyota I've yet to see it happen. Most likely it just gets dirty. Probably giving wrong ambient temps.
Old Oct 26, 2020 | 05:08 PM
2013FSport's Avatar
2013FSport
Someone recently replaced the AC computer controller for a problem like this and fixed. IIRC It was a new post in the last month. I'm not saying that's it, but with Fusion OBD app and the Lexus PID pack you could for about $45 diagnose it yourself. You need an OBD II Bluetooth dongle.
Old Oct 26, 2020 | 05:59 PM
bez88hlb's Avatar
bez88hlb
Im thinking it’s the amplifier also or maybe relay...do you know is there just the 1 relay under the hood for a/c comp or is there a separate relay for the motor blower itself? Figured I’d change that before trying the ac amplifier since a relay is like $10 bucks
Old Oct 26, 2020 | 07:29 PM
BabyGate's Avatar
BabyGate
The is no serviceable relay for the blower motor. The speed controller is on the A/C Amplifier. If you have a volt meter, i'll first check the power wire (the blue one on the harness plug), and make sure there is 12v there. If there isn't, check the 50A HEATER fusible link It is most likely blown. While you are there, check the Ground wire (white black strip) too. If there is power, then the A/C Amplifier is probably faulty.
Old Sep 20, 2025 | 10:27 AM
Gron's Avatar
Gron
8th Gear
Default Resolution
My cabin temperature sensor is missing also. Anyone have a pic of the harness?
Old Sep 24, 2025 | 04:35 AM
Gron's Avatar
Gron
8th Gear
Default Update
The harness was behind the radio. eBay has the sensor for $25.
antigeek
RX - 3rd Gen (2010-2015)
Dec 28, 2019 01:08 PM
rcmike1234
Apr 2, 2018 10:27 AM
chenxingha
RX - 1st Gen (1999-2003)
Jun 7, 2011 09:03 PM
99es300
Jul 29, 2006 06:53 PM
