engine swap 09 is250 with a 06 is250 engine
Old Nov 28, 2018 | 12:23 PM
coleruffle's Avatar
coleruffle
Default engine swap 09 is250 with a 06 is250 engine
hi i have a 2009 is250 rwd, i found a 06 is250 rwd engine and was gunna swap it, the engine comes with the wiring harness but not the ecu, would i be able to just plug and play or would i need the ecu from the 06 and have to put that in instead of running off the original 09 ecu ? thank you for any help
Old Nov 28, 2018 | 02:40 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Same same, should be straightforward.
Jeff
Old Nov 28, 2018 | 03:25 PM
coleruffle's Avatar
coleruffle
Thank you so much for the help
Jesse724
Apr 3, 2025 05:58 PM
UtopiaBe
Jun 21, 2024 05:13 PM
bluffrides
Feb 4, 2017 06:57 AM
Karpal
Mar 17, 2016 05:17 PM
ESCAPED
Jun 6, 2009 04:51 PM
