need help (advice)installing coil overs
Old Oct 17, 2018 | 05:35 PM
thaiVo's Avatar
thaiVo
nah couldnt do it trying to remove the lower control arm completely was too difficult , i think my last resort is to cut the springs and see what happens
Old Oct 18, 2018 | 06:08 PM
2013FSport's Avatar
2013FSport
Sounds like the anti-sway bar is fighting you. To be on the safe side, unbolt the link from the opposite side. It is likely under a good bit of strain.
Lets say the front end is suspended with wheels off. The sway bar in place and the spring is no longer contained by the coil over on one side. This sounds like your issue.
You have two choices.
1. Jack up the LCA of the un contained spring until you can remove the sway bay link from the other side. Lower the LCA to remove shock and spring.
2. With a jack under the contained side, unbolt the 3 bolts holding the contained spring and lower the LCA. This may or may not be enough until the sway bar is disconnected from either side or BOTH sides of the chassis mount.
Make sense? One of these methods should work. You have to equalize the sway bar pressure before it can be undone. OK
Old Oct 18, 2018 | 06:14 PM
2013FSport's Avatar
2013FSport
FWIW when it comes time to assemble this, DO NOT tighten those new coil over shocks IN PLACE with the wheels hanging down!!!
It will destroy the lower bushing in your new coil overs!
lower the car onto ramps, bounce on it a few times and then tighten the pinch bolts securing the shock bushing.
Old Oct 19, 2018 | 05:29 AM
thaiVo's Avatar
thaiVo
thanks for the help man ,i finally finished installing them your a life saver .
Omen766
IS - 1st Gen (2001-2005)
Apr 4, 2017 10:13 PM
kanklez
Suspension and Brakes
Nov 25, 2010 03:03 PM
sphy1005
Dec 29, 2005 07:15 PM
KrochRoket
Oct 20, 2003 12:29 AM
