2008 Lexus IS250 no power
Old May 21, 2018 | 05:18 PM
Chrisl0516's Avatar
Chrisl0516
Default 2008 Lexus IS250 no power
Hi guys,
just bought a 2008 IS250 at an auto auction with 127k miles car drives very smooth. Check engine was on with the tracción control light. Following day I took the car to work, and at night time came back home. 2 days later I try to turn on the car to warm it up and it does not turn on. When I press the brake the green light on the button does not come on. Only thing it does when I press the button is turn on the dash. I tried jumpstarting it, I put the battery from my rav4 which is also 700CCA and no luck.
Does any one have any ideas what could be going on with this thing!? I put the key fob next to the start button also no luck
Old May 21, 2018 | 05:35 PM
2013FSport's Avatar
2013FSport
I would think it would still start with those errors.
There are two sensors atop each valve cover. They are black and retained by a single bolt. Inspect the wiring harness for rodent damage. But no clue why this would happen out of the blue. Well unless rodent induced.
Does the engine spin over but not run, or does it not crank over at all?
Old May 22, 2018 | 05:08 AM
Chrisl0516's Avatar
Chrisl0516
Does not crank at all, I took it to my mechanic I’ll give you guys an update once I get it back
Old May 22, 2018 | 10:02 AM
timmy0tool's Avatar
timmy0tool
check your key fob battery. sounds like the car is not recognizing the key!
merle847
Dec 27, 2017 04:33 PM
Mylexus250
Jan 2, 2016 02:12 PM
GSLEX0586
Dec 28, 2011 09:05 AM
