Lexus 3.5L longevity
Old Jan 16, 2018 | 07:11 AM
DMV350's Avatar
DMV350
Old Jan 16, 2018 | 08:37 AM
WhatYaGot's Avatar
WhatYaGot
Originally Posted by awdlyfe
Thanks for all the responses guys. This is great to hear.
"whatyagot", wow, that is amazing. Has anything major been repaired or replaced besides maintenance ? If you don't mind me asking, what grade of oil are you using ?
Water pump at 80k and the regular oil changes and brakes. I'm using Mobil 1 5W20 full synthetic. I have also used Seafoam in the oil 500 miles before a oil change and directly in the fuel tank. Look at my post about how clean the top of my pistons are at 200k miles. I put a camera down each spark plug hole and posted the video.
Old Jan 16, 2018 | 09:10 AM
Mufis's Avatar
Mufis
2nd owner(138k miles bought)06 id350 lux option w/sport package fully loaded( big brake opton from factory) everything is good besides the alternator. Atm (146kmiles.
Old Jan 16, 2018 | 02:10 PM
awdlyfe's Avatar
awdlyfe
Ok, thanks for sharing. I will check that out.
Old Jan 16, 2018 | 02:11 PM
awdlyfe's Avatar
awdlyfe
Out of curiosity, considering this is a lexus forum, can any one attest to the comparison to reliability of the g37x/q50 ?
Old Jan 16, 2018 | 02:39 PM
DMV350's Avatar
DMV350
Old Jan 16, 2018 | 05:11 PM
Aspect's Avatar
Aspect
The Infiniti Gs are all pretty reliable with that 3.5 or 3.7 VQs. When I did my research the only things that usually went wrong were all the electronics like the CD changer. My friend's G37X's rear camera broke and the rear trunk started rusting prematurely. The Q50 I've heard rumors of it being a troublesome car and would probably stay away, plus it has steer by wire boooooo.
Old Jan 17, 2018 | 02:23 PM
awdlyfe's Avatar
awdlyfe
Great. Thanks.
Old Jan 17, 2018 | 02:49 PM
andper10's Avatar
andper10
Originally Posted by DMV350
NO don't tell me that! I'm approaching 80k
My Carfax wasn't very informative, but as far as I know, the previous two owners never replaced the water pump.
Does it just fail all at once, or are there warning signs?
Register at the Lexus Owners site with your VIN and you can see all past dealership service records. If you search this 2IS forum there is a video of the noise a failing water pump makes and you may be able to see leaks or crusty dried pink coolant residue around the water pump area if it is starting to fail. You might need to remove the big plastic undercover and/or use a small inspection mirror from the top to check all possible angles.
AMGL
Oct 15, 2018 03:38 PM
gearman
Jan 6, 2017 01:52 PM
JTLexus1
Jun 3, 2015 08:59 PM
BugginOuT
Mar 30, 2013 02:52 PM
Crzyxcrys
Jan 14, 2012 09:44 AM
