Axle
Old Nov 14, 2017 | 01:24 PM
Lbckhmaibo's Avatar
Lbckhmaibo
Default Axle
hey I need help I order axle for my Lexus IS250 2007 rwd and one side was perfect and one side was to short does any1 no wat the length of the axle dis my 2nd time I order
Old Nov 14, 2017 | 07:20 PM
Mrfix's Avatar
Mrfix
Driver Rear 30 11/32 "
Passenger Rear 32 5/32"
http://www.rockauto.com/en/catalog/l...+assembly,2288
Old Nov 29, 2017 | 11:46 AM
PandaBear's Avatar
PandaBear
Stay away from Cardone reman axles, or Chinese new axles in general unless you are repairing then selling. Cheap reman just grind the surface of the joints and repack the grease, and grind away the heat treatment on the surface make it much softer and it will then go bad very quickly. Cheap Chinese axles also probably don't have the necessary heat treatment to make it durable like OEM.
When I replace axles on my cars I always go with either OEM reman (Honda / Acura sold them), new OEM, junkyard pull from a non accident total (accident may damage it), or a reputable shop that rebuild with new heat treated joint. My 2 OEM reman axles on my Integra cost me $170 each. New would be around $300 each.
glenmore
Feb 26, 2007 12:07 PM
ColtSwitch
LX570 / 470 / 450 Classifieds
Nov 14, 2006 07:23 AM
