Ebay Bumper 2IS to 3IS Conversion
Subscribe
Mar 4, 2019 | 03:06 PM
  #136
www.ebay.com/itm/ToyotaC-HR-Fog-Trim
Reply 0
Mar 4, 2019 | 05:38 PM
  #137
Quote:
thanks so much for the information !!!
Reply 0
Apr 4, 2019 | 02:44 PM
  #138
Front lip install?
Hey so I've watched you're YouTube. What hardware did you use to install the front lip? You drilled and added some sort of tabs? Double sided tape I'm assuming? I got my bumper on waiting on my lip to get painted.
Quote:
Lip for this bumper ordered separate from Ikon for $100. This came in 2 days since they shipped from their Atlanta drop ship warehouse.
Had to drill and fit to bumper. Lip is designed to sit against the raised edge on bumper b
There gaps near the curves, so need to strategically grill screw holes and put them on backside. I used two screws per side
Happy with it, the lip is pretty thin Plastic so may not withstand any major hits or scraping over time.
Reply 0
Apr 8, 2019 | 07:07 AM
  #139
No tape. Just the old nut tabs from previous lip with the 10mm screws. The added a few nylon bumper nuts from Amazon with more 10mm screws from old bumper.
Screws (25 pack, $15):
https://www.amazon.com/gp/product/B01BSG0D10 https://www.amazon.com/gp/product/B01BSG0D10
Nylong nuts (20 pack, $9):
https://www.amazon.com/gp/product/B078RQF8FP https://www.amazon.com/gp/product/B078RQF8FP
Reply 1
Apr 25, 2019 | 01:28 PM
  #140
Need Your Expertise
Hello all,
Newbie here. I have a 2012 IS250C with a front end damage that I want to convert to 3IS kit from IKON. I called them and they're currently out of stock until another 3 weeks. My questions:
  • What other place or store can I buy this kit because 3 weeks is a long time to wait.
  • Will this kit fit or is there another kit for the C model? After reading some posts, I understand it will be some heating, cutting, adjusting involved and I'm ok with it as long as it will fit ok overall.
Thank you!
Reply 0
Apr 25, 2019 | 02:26 PM
  #141
Theres a nib one for sale on Craigslist . Norfolk Va
Reply 0
Apr 25, 2019 | 02:43 PM
  #142
Quote: Theres a nib one for sale on Craigslist . Norfolk Va
Is that the one from IKON posted 17 days ago? I called them before and they're out of stock. Thank you.
https://norfolk.craigslist.org/pts/d...861005136.html
Reply 0
Apr 25, 2019 | 04:37 PM
  #143
Local seller here. Guy must have sold his car before mounting it.
Reply 0
Apr 26, 2019 | 03:01 PM
  #144
There's another seller on Ebay that sells same bumper. Ikon and advanced tuning are the same.
Reply 0
Jun 25, 2019 | 10:49 AM
  #145
Hey mines came with led lights....wires are coming out of each one. My question is should I crimp all of the negatives on the bumper and the positive together? Then cut the oem fog connector, splice it and then run the neg to neg crimped from the bumper wire and pos to pos, etc. is that correct? Please help as I’m trying to finish this job today! Thank you in advance
Reply 0
Jul 3, 2019 | 08:18 AM
  #146
Quote: Hey mines came with led lights....wires are coming out of each one. My question is should I crimp all of the negatives on the bumper and the positive together? Then cut the oem fog connector, splice it and then run the neg to neg crimped from the bumper wire and pos to pos, etc. is that correct? Please help as I’m trying to finish this job today! Thank you in advance
Best advice I would give is head to you local hardware or electronic store, grab some T-Tap connectors, they're really cheap, no splicing required. Use those and go straight into the fogs (negative-negative etc) on each corresponding side, just make sure the wire aren't too long and hanging. It will be a lot cleaner, and easier to undo. If anything were to go wrong (one side doesn't work), it should be easier to isolate the problem.
https://www.google.com/search?q=t+ta...iw=412&bih=691
***When you clamp them just give them a little spin to make sure they cut all the way through the plastic sleeves and contact the wire the first time.
Reply 0
Oct 23, 2019 | 08:38 AM
  #147
Hello, aside from the minor stuff you mentioned. Does this directly fit?
Reply 0
Nov 14, 2019 | 10:46 PM
  #148
I've reached out to someone who did the conversion on there ISF and said that the following seibon lip fit well onto the converted bumper. Has any one tried this out?
https://seiboncarbon.com/products/fp...s-250-350.html
Reply 0
Dec 10, 2019 | 09:00 PM
  #149
Finally Busted my lip. Had to repair it.
Plastidip Metalizer ($15):
https://www.amazon.com/Plasti-Dip-Performix-11247-6-Metalizer/dp/B00P8XAGLW https://www.amazon.com/Plasti-Dip-Performix-11247-6-Metalizer/dp/B00P8XAGLW
Black Plastidip ($5) (also at Walmart):
https://www.amazon.com/Plasti-Dip-Black-Metalizer-Kit/dp/B079MGSXHG https://www.amazon.com/Plasti-Dip-Black-Metalizer-Kit/dp/B079MGSXHG
JB Weld Plastic Weld ($6):
https://www.amazon.com/gp/product/B01IBOK7FE https://www.amazon.com/gp/product/B01IBOK7FE
Soldering Iron I used ($17):
https://www.amazon.com/gp/product/B074W3W55T https://www.amazon.com/gp/product/B074W3W55T
Reply 0
Dec 12, 2019 | 06:40 AM
  #150
Been getting some PMs and questions about the aftermarket OE color grill and emblems.
Here are the ones I used from e-Bay. I like the color much better than the black ones that the bumper comes with that has holes for Japan/Euro license plate.
Aftermarket $60 Lower Grill www.ebay.com/itm/AM-Front-Lower-GRILLE-LOWER-For-Lexus-IS250-IS350
Aftermarket $61 Upper Grill www.ebay.com/itm/AM-Front-UPPER-Grill-For-Lexus-IS250-IS350
Aftermarket Hybrid Style Blue Emblem $33 www.ebay.com/itm/AM-Front-EMBLEM-For-Lexus-IS250-IS350
Aftermarket Black Emblem $32 www.ebay.com/itm/AM-Front-Lower-GRILLE-UPPER-For-Lexus-IS250-IS350
Reply 1
