Steering Wheel Popping noise?
You've done good detective work to help isolate the issue to a specific area. The video isn't much help because there was so many different noises; hard to tell what was the "popping" vs other sounds. But my first thought would be to look into a the airbag clock spring.
Does the noise only happen with the engine running or does it do it as well while in "accessory"? Have you adjusted the tilt up and down and in and out to see if that helps?
I couldn't tell what was what making sounds in the video either, but my first though was clock spring as well. Do all the controls on the steering wheel and the shift paddles work as they should?
Sentinel
09-07-12 01:30 PM
tieu
02-27-09 04:51 AM
