How to make this sub enclosure secure and not move?
Old Jun 18, 2017 | 10:05 PM
metaleckz's Avatar
metaleckz
Default How to make this sub enclosure secure and not move?
I bought this slim sub enclosure that fits in the spare tire well. however, theres still a lot of space left and i was wondering if any of you guys have any idea to secure this box in the spare tire well?
Old Jun 19, 2017 | 09:42 PM
metaleckz's Avatar
metaleckz
Old Jun 20, 2017 | 08:05 AM
Nespo2330's Avatar
Nespo2330
There is no need to secure it with screws or adhesive, all that you can do is extend the surface area of the enclosure to the edges of the spare tire area so it'll maintain its own position. MDF is heavier and will stay in place..
unless youre off-roading lol
Old Jun 20, 2017 | 11:09 AM
Gville350's Avatar
Gville350
Wood spacers (aka, scrap wood leftovers) cut to fill the additional empty space on each side.
Old Jun 29, 2017 | 01:31 AM
marcsis250's Avatar
marcsis250
yes, if you look under your box iirc there is a point in which your spare tire bolts too. you could use a longer bolt and then make a hole in your box and secure it through the hole into the threaded part in that. also since your box is sitting on that flat rail that goes across the
spare tire well you could match up the two holes (one on each side of center hole) and secure it the same way. my amp rack in my car has a base board that is secured to that middle rail.
good luck
CRASHMONK
RX - 1st Gen (1999-2003)
Jun 28, 2017 07:51 AM
bbond
Mar 29, 2015 07:55 AM
jvsc300
Apr 19, 2009 02:30 AM
Soybomb
May 22, 2007 11:11 AM
nysupraman
May 9, 2004 02:19 AM
