Check VSC, ABS light on, AFS flashing
I drive a 2006 IS 250 manual tranny. These lights would come on once in awhile and I finally figured out what triggered the lights to come on. When I go in reverse I will put car into 1st gear while still rolling sightly and engage clutch to move forward. This seems to trigger the lights to come on. Any ideas why this action is causing all the lights to trigger? Thanks in advance! Haven't had a chance to pull codes so I cannot give any details on that. Sorry.
brake fluid low?
Originally Posted by Torii
(Post 9889649)
brake fluid low?
Not sure why it's happening during that action, but if you ever get under the car I would unclip the abs sensor wire in the wheel hub and put it back on to see if it resets anything.
Originally Posted by Raar
(Post 9890007)
