Coolant problem HELP
Old Nov 1, 2016 | 08:43 AM
Kazp's Avatar
Kazp
Default Coolant problem HELP
Hey im new and sorry for my language.
Polish forum fans lexus isn't helps. Ignored my problem.Topic temperature cdn.
Even a fool, until finally ordered a new thermostat and zobczymy or something will change anything As you go mention.
Maybe someone something to me from the forum will tell
Note the position of slightly less than half (Where was left). Some time ago I moved a little to the top What bothered me (MIMO developer remains non-stop weight this higher position) - invalid plug in the City of whether the route.
ElmScan Toyota / Lexus shows the value of 93 degrees Celsius, of course, as heating to the max, the temperature drops temporarily as shown in the chart
SDProg and shows the values ​​of other Toch
Temperatrua liquid during the ride so roughly 85 degrees Celsius (normal), a screenshot of the graph temperature while driving, unfortunately, did not do
In contrast, once the temperature of the parked 85 degrees Celsius began quite quickly raise. At 93 degrees or even 95 degrees fans not annexed (I can not come from how many degrees fans begin to blow).
The thermostat opens, because the hose is warm (maybe more than a warm ... and hotter), a snake coming out of the radiator (to the right of the thermostat) - there is mega hot, it's hard to maintain it is also hard)
Water pump turns, no leaks, no noise
The fluid is not diminished in the coolant expansion between the min / max.
I would add that the exhaust slightly flies steam, even as it warms up. Sticking his fingers in the water muffler feel. In addition, I would add that the smoke is odorless (or not feeling) and not very dense. It is not always visible.
Old Nov 1, 2016 | 09:20 AM
Zmon's Avatar
Zmon
If you replaced the thermostat and it is still overheating, then you may have air bubbles in the system that need to be burped out.
Driving, not idling the car, will usually keep the temperature within range as the wind will cool it down. Now at idle, if your fans are not coming on at all while the car heats up, you most likely need to replace your thermostat (or it's possible the fan relay is bad if they don't come on at all even with a good thermostat), or another possibility is that you have a low coolant level, which may be indicative of other problems such as a leak somewhere (water pump, hoses, etc) or a blown headgasket (which you would see coolant in your oil if that was the case)
Old Nov 1, 2016 | 10:00 AM
Kazp's Avatar
Kazp
The oil in the engine is clean. Since the exchange or 7000 KM nothing disappeared.
The problem is only elevated temperature.
Are both hoses from the radiator to be hot?
The optimal temperature in the cooling system to 90 degrees Celsius Lexus or more?
Radiator should at which temperature the liquid to turn?
Old Nov 1, 2016 | 08:40 PM
ezbmr's Avatar
ezbmr
The lexus I saw had one hose in the tube and another just dangling out. Is it supposed to just sit there draining in the engine bay?
Old Nov 6, 2016 | 07:01 AM
Kazp's Avatar
Kazp
Ok. I changed the thermostat but.....- old thermostat was good.
I got rid of the bubbles, I completed the new coolant, etc.
Temperature indicator remains in the same position.
Temperature of elm scan reaches 95 degrees Celsius and fans starts. After turning fans temperature drops to 87-89 degrees Celsius.
It seems to be all about, there is nothing to worry about?
Old Nov 6, 2016 | 05:41 PM
Gville350's Avatar
Gville350
I'd say as long as the temp doesn't climb any higher than that, you'll be fine. Do you have any larger, long uphill roads you can test the cooling system on? Going up a mountain road would definitely test whether the cooling system is up to the task or not.
Old Nov 11, 2016 | 02:41 AM
Kazp's Avatar
Kazp
My new thermostat open in 93 degree celsius.
Fans start in 95 degree coolant.
Yesterday i drive 2h in traffic jam, coolant temperature max 95 degree celsius.
when fans go coolant temperature drop to 89 degree celcius.
Next higway 180km/h and collant temperature hold 90 degree celcius
tip temperature all the time persists at the same level.
Idk its all ok, or no.
Tech doc- thermostat open in 82C.
My new thermostat full open 93C
axkxa
Aug 13, 2014 12:21 PM
pearl95lex
Apr 5, 2012 08:14 AM
mjes300
Aug 5, 2009 05:40 PM
ontoy
Jun 18, 2006 10:06 AM
