Help with the heat is250
Old Feb 27, 2016 | 04:53 AM
Feraseze's Avatar
Feraseze
Default Help with the heat is250
I just buy a is250 07
I found this problem when i start the heat the driver side will not bee warm like the passenger side and when i am driving the heat will go up and down can someone help
Old Feb 27, 2016 | 06:55 AM
Gville350's Avatar
Gville350
Check your water pump for leaks and the level of coolant in the overflow.
Old Feb 27, 2016 | 07:19 AM
Feraseze's Avatar
Feraseze
Yes you are right it was the water level
Thank you for your help
kgrize916
Aug 27, 2017 11:15 AM
OneTrue1
Dec 21, 2016 09:05 PM
tidiiz
May 5, 2011 09:53 AM
XeroK00L
Nov 15, 2005 02:31 PM
