Hey the wires came out the connector to the cam sensor on the driver side. Can anyone help me. Have 3 wires 2 greens and red
Thank you in advance
As in, what color goes where or how to repair?
You might consider hitting the graveyard for a used connector and splice them with butt connectors and shrink tubing orhers order the replacement connector and the appropriate crimp tool.
Thanks i was lucky enough to find them at my local graveyard. Heading home now. If yall curious how it happened. I was replacing my alternator and the wires came loose from me moving them around to get the alternator out
Can this be used to test accurately? It seems this issue is popping up regularly now. As the model ages and what not. I would suspect brittle connectors showing their age. This will be a regular occurrence.
