Precautions when Changing Battery ?
Old Oct 3, 2014 | 11:17 AM
SPS's Avatar
SPS
Default Precautions when Changing Battery ?
Probably its just a dead battery. I got my battery disconnected from the car right now, trying to see if it will take a charge.
Just thought it would be prudent to check with the forum if there are any particular precautions to take when connecting a battery. ( i.e a little concerned about buggering any of the electronics) ???
I tied to start it up yesterday, and battery was half dead, would not start. I saw a warning "hatch ajar", but figured the battery should be able to run the bulb in the trunk for a day or two without problems. I closed the trunk and took my other car to my appointment, and when I got back, electrics were totally dead. Strange that it discharged on its own.
Old Oct 3, 2014 | 11:30 AM
getafewliv's Avatar
getafewliv
Negative off first, back on last. Shouldn't have any issues.
I took my battery in and out like 10 times when I was trying to get my ISF steering ECU working.
Old Oct 4, 2014 | 10:59 AM
DryEye's Avatar
DryEye
at stated in the previous post:
1. disconnect the negative terminal first
2. disconnect the positive terminal
3. remove battery tie down
4. remove old battery and install new battery
5. reconnect battery tie down
6. reconnect positive terminal first
7. reconnect the negative terminal last
8. have a beer for a job well done!!!
worker
Mar 22, 2025 02:26 AM
RomanTPA
Jan 22, 2017 09:48 AM
tradosauru
Feb 10, 2016 06:30 PM
skelow401
Sep 6, 2011 04:36 PM
