What to do flooded my is350
Old 06-21-14, 05:55 PM
08is350x
08is350x's Avatar
Default What to do flooded my is350
So it rained very hard over and I couldn't see and I got suck in the water. The car turned off and now won't start it only makes clicking sound. So what should I do wait to see if it will start up or call the insurance company.
Old 06-21-14, 06:00 PM
getafewliv
getafewliv's Avatar
Yeah... you're going to have to do a better job explaining what happened. So it was raining hard, then what?
If your car is just clicking, I would assume your battery is almost dead. Unless you can explain more about this heavy rain. Did your car get submerged? Did the water come in contact with vital electronic components?
Old 06-21-14, 06:14 PM
08is350x
08is350x's Avatar
Yea my bad yes my car did get submerged and it does sound like the battery is dead, but the battery isn't wet but most of the engine bay is. I also took out my air filter and it was soaked. Water probably did come in contact with vital electronics. Also my front bumper fell off.
Old 06-21-14, 06:20 PM
tex2670
tex2670's Avatar
Nothing to do but call the insurance co.
Old 06-21-14, 06:30 PM
08is350x
08is350x's Avatar
That's what I was thinking but my car is lowered so I'm not sure if they would cover it.
Old 06-21-14, 06:32 PM
Justin2JZ
Justin2JZ's Avatar
You have your stock suspension? If so Id swap it out before I contact insurance
Old 06-21-14, 07:10 PM
getafewliv
getafewliv's Avatar
Ouch... that sucks. If the water was high enough to flood your engine bay, you don't want that car anymore. Even if you can get it running, you will run into so many electrical issues down the road.
I don't think the fact that your car is lowered should have any effect on flood insurance. I would put up a hell of a fight if they tried to pull that card. My recommendation is to take everything off of the car that is worth money or that you want, then make the claim and try to get enough to replace the car. Then either put the parts on the new car or sell the parts.
Old 06-21-14, 07:14 PM
sha4000
sha4000's Avatar
Did you actually drive into the water without realizing how deep it was?
Old 06-21-14, 07:20 PM
Gville350
Gville350's Avatar
Sounds to me that the engine is hydrolocked from drinking water. Call the insurance company ASAP!
Old 06-21-14, 07:26 PM
my07is350
my07is350's Avatar
I just hope it's not hydrolocked (water got sucked into the engine because the intake is under water) when you drive thru a deep puddle without realizing it.
Old 06-21-14, 10:47 PM
WNYX
WNYX's Avatar
08is350x, what part of IL are you at? I know it rained buckets (I got stuck in the rain as well), but I didn't think it rained enough for floods. Did water get into your engine because your front grille fell off?
Old 06-21-14, 11:39 PM
08is350x
08is350x's Avatar
I'm in niles, I didn't think it rain enough either but the tow truck driver said that the place I got stuck in always floods because the water backs up to that drainage because its the low spot of the city. The reason it flooded was because the water was almost the same height as the hood.
Old 06-22-14, 05:07 AM
SC430inVA
SC430inVA's Avatar
If the engine was running and the water was that high it probably pulled in water through the exhaust and from your description, possibly through the intake. Call insurance company. They probably won't know a lowered vehicle from a regular. Good luck
Old 06-22-14, 05:47 AM
tboo72
tboo72's Avatar
It depends on the insurance inspector. I know several experienced insurance inspectors that would spot a lowered car right away. They are trained to look for that stuff-anything to get the insurance company out of paying to replace/repair the vehicle.
I have USAA and back in the day, when I used to modify my cars, I would declare my modifications to them when they were installed. They were pretty good about honoring the insurance if all modifications were declared to them beforehand. I guess it depends on who is your insurer and if you declared your modifications to them.
Old 06-22-14, 06:45 AM
idoke1
idoke1's Avatar
^^tboo72 is right. There are several trained insurance inspectors who will know aftermarket to oem.
Quick Reply: What to do flooded my is350
