View Poll Results: Your mileage at the time of responding to this thread
20K
16
4.55%
40K
34
9.66%
60K
49
13.92%
80K
55
15.63%
100K
66
18.75%
120K
47
13.35%
140K
29
8.24%
160K
23
6.53%
180K
21
5.97%
200K
0.57%
220K
1.14%
240K
0%
260K
0.57%
280K
0.28%
300K +
0.85%
Voters: 352. You may not vote on this poll
Lexus IS reliable? Show us YOUR numbers!
#78
2007 IS350 sport pkg
51K miles
Repairs: brake light switch
Othewise routine maintenance, Mobil1 via Lexus dealership. Lots of recalls of course.
Edit: Yes it's reliable. Still has original battery, rotors, brake pads (actually front pads changed to low dust version at 29K per TSB, no charge).
51K miles
#81
Year - Model: 2006 IS350
Package: Luxury
Miles: 125,000
Beside regular maintenance, what has been broken and repaired?
- Dash was replaced twice by first owner in 2007. Fuel Pump died at 120,000. That was a fun $1300 mid roadtrip fix... Also, the dealers were hoarding fuel pumps and there were only 18 in the US, so I had to go with an aftermarket replacement.
Package: Luxury
Miles: 125,000
#82
- 2006 IS350 RWD
- 105k Miles
- Maintenance - 100k Tune Up+ (Water pump, coolant flush, oil change, oem to blitz filter, cabin filter change, spark plugs changed, and wipers)
So far still running strong just concerned about the transmission failure soon, semi downshifts and upshifts a bit aggressive and have already done the battery reset. Crossing fingers, I hope Lexus does a transmission recall due to the wear and tear on a "sealed" transmission.
- 105k Miles
#84
07 IS350
Luxury package
130K
just did a suspension overhaul. the only thing that needs to be replaced now is the rear knuckle assembly. It has a bushing/bearing that connects to the lower control arm. Those are shot and that is what is making my car have little bounces when driving. i tried to replace just the bushing itself, but its a PITA. might just have to buy the whole new assembly.
engine is good!
Luxury package
130K
engine is good!
#87
2007 IS 250 X-pkg
103,000 miles and running strong.
dash replaced no cost due to melting. engine re built at 85,000 miles(carbon) water pump replaced.
No other issues other then routine maintenance, tires, pads etc.
#88
2009 is250 AWD
86,000 miles
Had alternator replaced at 50k, carbon buildup recall/water pump at 60k. 1 ceased rear caliper and blown shock replaced at 85k. All under warranty. Rest has been routine maitenance. Runs good.
86,000 miles
#89
Year - Model:
2006 IS350
Package:
Base, Nav, htd/vented seats, leather
Miles:
120k+ miles. Got it used 10mos ago, since then: Nav screen freeze (replaced screen), windshield washer pump failure (replaced), fuel pressure sensor recall (completed), basic maintenance. Not too bad compared to my Audi A4 (B6) 1.8T, failures one after the other since day 1...oh and that dreaded CEL..arrgh. Not an issue with my IS350.
2006 IS350
Package:
Miles:
#90
2007 IS 350 now at 100k miles
Bought it used in 2011 at 55k miles
At 2012 replaced original battery, navigation screen
At 2015 replaced water pump, front crankcase seal, (2) engine mounts
