Warranty covers this?
^Sorry, that is a "wear" item...like brake pads.
EDIT : found this online that Lexus WILL warranty under the factory powertrain warranty :
REAR-WHEEL DRIVE SYSTEM
Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets:
^Sorry, that is a "wear" item...like brake pads. EDIT : found this online that Lexus WILL warranty under the factory powertrain warranty : REAR-WHEEL DRIVE SYSTEM Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets:
Luso
20
Jan 31, 2018 03:32 PM
