IS350 brake kit on IS250 help
you need to get new rotors to make them fit.. thats all..
oh and either take off the dust shield or bend it backwards so you can fit the bigger rotor in..
get same brake fluid to bleed the system.. dont forget the new pads..
Autozones ceramic gold are teh best.. no dust at all
Did you end up picking up a brand new 350 brake kit or finding something used at a junk yard? I'm looking to do this shortly as well and wanted to see the best way to go about sourcing parts or a good price.
Things you'll need, with OEM part numbers if you want them:
Brake Calipers (47730-22460 and 47750-22460)
Brake Hose to Caliper Banjo Bolt Gaskets (47389-50020 x 2)
Brake Pads (04465-30410 - Textar T4146 High Friction or 04465-30450 - NBK D6893H Low Dust)
Brake Pad Shims (04945-22152)
Brake Pad Anti-Rattle Clips and Retaining Pin (04947-22070 and 47735-50020 x 2)
Brake Rotors (43512-22260 and 43516-22010 - RWD Only, 43512-30350 and 43516-30040 - RWD or AWD)
Brake Backing Plates (47781-22200 and 47782-22200 - RWD, 47781-30240 and 47782-30240 - AWD)
Jeff
Jeff
Carson-Lex
Club Lexus Vendor Marketplace
Nov 25, 2011 11:39 AM
