Play Music through Galaxy S4
I searched and couldn't find anything... When I plug an auxiliary cable into the port in my center console and then into my Galaxy S4, no music plays through the stereo. Anyone else have this issue or can recommend a cable that will work? I'm dying listening to the radio. Thanks!
I just tried it again and made sure I pushed the Aux button and no sound. I used to play my Iphone with no problem, but it used a different cable. What cable are you using?
What cable are you guys using that has good sound quality? I used the Kensington cable for my iphone and it worked great, but I don't think they make one not for iphone. I hate just buying one only to find out it plays through 1 speaker or the quality is terrible. Thanks!
If your S4 is like my S3, where the headphone jack is a lil finicky, try moving the cord within the phone and make sure the phone shows that a headphone is connected.
Also when you play music does it at least play through your phone?
Also what year IS do you have, i believe 2010 + it has bluetooth, in my car when i want to listen to pandora i just connect through bluetooth so i dont have to worry about connecting cables
It's an 09' so no bluetooth. Everything on phone works good and music plays just fine through headphones. So it seems like the cable is the issue, but I don't know what cable to get as Amazon has a lot of bad reviews. With that being said the cable works fine in my Type R when plugged into the top of my iphone...weird
go buy Blackberry Music Gateway or something similar...
My friend has the S4 and he had to get a samsung docking cable to play music in his truck. It all plugs in at the bottom charger port and its two cables that come out, USB (to go into the cigarette lighter charger) as well as an AUX for the car. Why does it play like this, I have no idea because headphones work perfectly fine in it. That company IBolt has it but the cable only comes with the whole car mount. Couldn't find it separate
Super Moderator
Super Moderator
I've never had one in-hand, but the specs say it's 2.385" long; I can't imagine that's going to fit. You'll need a 3.5mm extension cable, or if you are out-of-warranty with an older IS that never had the ground loop isolator TSIB done, an external ground loop isolator with 3.5mm connectors would do it too.
