LED headlamp connector
Anyone know what the 3 pin white connector inside the LED headlamp unit is for? here's a picture below, there are two white connectors, one is without anything and has 3 pins on it and the other is connected. also, anyone know which connector pins power the LED unit?
nevermind, i figured it out, this is the input connector to power the entire led strip. with the connector facing up the pin on the left is ground (negative) the middle pin and pin on the right are +12v pins but the middle one operates the LED's at low intensity and the one on the right powers the LED's at full intensity of 11.7W whereas the middle pin operates it at 0.7W
