ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   IS - 2nd Gen (2006-2013) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013-163/)
-   -   Trunk won't open!? (Not the Vallet button) (https://www.clublexus.com/forums/is-2nd-gen-2006-2013/680097-trunk-wont-open-not-the-vallet-button.html)
rookie350 Feb 23, 2013 09:41 PM
Don't know what happened- all of a sudden my trunk won't open, pressing the button on the back above the license plate- nothing. Unlock on my key FOB- nothing, unlock on the dash-nothing. Opens when I use the physical key, or the "girlfriend lever" though. Depressed and reset vallet button in glove box thinking it was that, still nothing. Plus it came out of nowhere, no dead battery or anything proceeding it, if anyone has any ideas before I take it to lexus please let me know, any insight appreciated, thanks
jecko714 Feb 24, 2013 12:05 AM
mine started doing this 4 months ago. anyone else ???????
DaveXIX Feb 24, 2013 07:20 AM
Check the fuse for the trunk latch?
tex2670 Feb 24, 2013 09:48 AM
There's a trunk latch fuse?
kevin125 Feb 24, 2013 08:00 PM
Listen carefully if you hear the latch being unlocked when you press the unlock button. if you can then that means all you have to do is re-adjust the latch and move it up. sometimes when you open and close the trunk alot or slam it too hard it will end up vibrating and move the latch down so the trunk will no release by itself. if you can not hear the latch being unlocked, press the unlock button on the trunk while lifting the trunk up so it will open. if this is successful you will need to adjust your latch which should take no longer then 15min. if this is not successful then you have a power problem. i believe there is a fuse for it.
MAKE SURE THE LOCK BUTTON IN THE GLOVE BOX IS OFF!!!
My friend is350 trunk would not open because the lock was on.
my1s250 Feb 24, 2013 08:09 PM
isn't there a thread that said there a trunk latch recall
https://www.clublexus.com/forums/is-...ix-recall.html
rookie350 Feb 24, 2013 09:42 PM
Thanks Kevin, checked it out tonight, listening for the click I'm so accustomed to was a great idea but it isn't that. I tried to listen to it both open and closed while pushing the buttons, definitely didn't make a noise, gonna have to look into the trunk latch fuse tomorrow I guess, thanks for the help/ideas tho.
rookie350 Feb 25, 2013 10:38 AM
sitting on hold with lexus service, anyone know off the top of their head if there is a fuse for the trunk latch?
