Is it possible to program only one TPMS sensor?
Old Aug 26, 2012 | 04:52 PM
GQis350's Avatar
GQis350
Default Is it possible to program only one TPMS sensor?
Is it possible to program only one TPMS sensor or does it have to be all 4? I got 3 that are currently on my wheels but I just ordered one single one. Planning on getting it programmed so my lights can finally not show
Old Aug 26, 2012 | 05:11 PM
projectdna's Avatar
projectdna
yes.
10char
Old Aug 26, 2012 | 05:57 PM
Road Rage's Avatar
Road Rage
Hook up a Techstream, write down all the sensor numbers, figure out which one is no longer working, add all 4 back in (including the new sensor number) viola! Set the pressures, push the initialization button and wait a few minutes, done.
If not using a dealership, then the process varies.
Old Aug 26, 2012 | 06:06 PM
GQis350's Avatar
GQis350
Damn so he's gonna have to mount off my tires to get the other 3 TPMS serial numbers?
Old Aug 26, 2012 | 08:35 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
No, the computer will tell you the 4 ID's that are programmed. Once you take out the old broken sensor you will know it's ID and can add the 3 that aren't that ID with the 1 new ID and then you've got the 4 sensors that are on the car.
Jeff
tucker21
May 19, 2016 05:26 PM
BieberNutz
Wheels, Tires & Brakes Forum
Jan 1, 2016 01:03 PM
EJ255t
Mar 7, 2015 04:06 PM
Bundy
Dec 18, 2007 03:04 AM
