Found Flyaudios Manufacturer
07awdis250, Can you start a brand new thread with a full review, please? Very interested, as it seems a lot of others, on your experience with this unit. Heck, given the Nav can easily add a $1k for resale, spending $500 is a no brainer even if one doesn't want to keep the car long term.
I dont know what the hell but my car doesn't want to start . The brake pedal is very stiff has anyone encountered this problem before? It cranks just finw but it does not start. Radio, lights ,windows work as well. Im also able to unluck and lock the car with the control.
UPDATE:
Sorry I havent posted a video as promised. Maybe someone here knows what's wrong with my car. I bought a fuse tester. I checked every single fuse, while i was checking the fuses I noticed that there were a few fuses that didnt make the light on the tester light up? I went ahead and replaced them. I have attached a pictures of all the fuses that have been replaced with new ones however, the tester does not light up when im testing the fuse. All the other fuses are fine and when tested they light up the tester light.
The brake pedal is stiff as hell. Im able to unlock the car using the FOB. Once I press the brake the start button goes green and when pressed the motor start to turn over but it does not start, if fels like it wants to start because is the motor is cranking just fine.
Everything with a mark next to it or circle in red is what is not lighting on the tester even though i replaced them with new ones.
