A weird DRL question
Old Jul 7, 2012 | 04:27 AM
12369874's Avatar
12369874
Default A weird DRL question
Hello guys, happen to have a set of H7 bulb with HID kit around, here is a newbie question that I need answers, will they be able to install as DRL/Highbeam? I know the stock ones are 9005, but I can kinda force it into H7?
Old Jul 9, 2012 | 06:49 AM
bob4256's Avatar
bob4256
I wouldnt. Why do you want HID DRLs? Just get a set of 9005 bubls, theyre cheap. Normally under $30
Old Jul 9, 2012 | 01:49 PM
ISCjonny's Avatar
ISCjonny
9005 and H7 are completely different bases.
9005 have 3 tabs that twist in, while H7 is a circle with a single tab that usually requires a tension wire to hold it in place.
Technically the HID kit all run at 35w. So its up to you if you want to ghetto rig it. But if it pops out while its on and causes other problems, then its on you.
Also, DRL runs at 25% power, so your HID kit wont have enough power to turn on unless you get a module. And if you drive around with HID highbeams, you gonna **** off a lot of poeple.
j three
Lighting
Oct 24, 2009 01:29 AM
Mnguyen409
Jul 19, 2009 08:43 PM
scdroptop
Mar 25, 2009 07:53 PM
sykocus
Dec 4, 2008 08:02 PM
jlin101
Lighting
Jul 22, 2004 03:15 PM
