check VSC message on the cluster display. Took to the dealer and waiting on them fix whatever is wrong. After reading the user manual, it looks like the engine control unit has a fault. NE1 knows what the problem might be?
Reason: added
That can be literally anything. Without reading the code(s) that caused the lights to come on you don't know if you need to tighten the gas cap or replace the entire powertrain or anything in between.
