sorry not sure how the heated mirrors with tilt will work this is strictly for the standard mirrors.
i love it def do it, when your doing the right side mirror one wire needs to be flip flopped when you do that hit me up or Brian at Tampa Automotive Center he figured it out for me.
I was able to super glue the two cracks. One on the JDM cover and one on the mirror housing. Everything working fine. But I'm so OCD...the two minor hair line cracks driving me crazy. Seriously looking to upgrade to the 09 OEM turn signal side mirrors. But now confused...what do you mean that I need to flip flop a wire on the right mirror. Since I ran the wires previously when I installed signal mirrors from Nigel, I plan to use the same wire and tap into the new mirror wire harness.
from your led covers you only need one wire which is the power wire, if you look at my directions thats gonna be the wire on each harness that does not exist on the other end. You wont need your ground cables. However if you just do the blinker cable and plug each side it the blinkers wont blink individually instead its like the hazzards are going off and your mirror controls inside wont work. There is a wire someone in that 09 wiring plug that is in a different pin. So you need to identify that only on the passenger side.
Okay...I starting to understand what your saying....first of all, I only need to tap into the power wire. Do you happen to remember what color wire for the left and right side. It appears to be the pink wire for the right side in your photo. Is this correct?
Thanks robertrios for your assistance. I do appreciate it.
if you already have the wiring from your blinker that hooks up to whichever one is "new" on the new plug disreguard color there will only be one on each side.
Nice work. I might consider this in the future over my current ones. I like the chrome on the new ones
Quote:
I also like the chrome.Originally Posted by Hoovey2411
Thanks guys for the info... I have not pulled the trigger just yet.... Might fill in the cracks and repaint current mirror
looks good. I wanted to do this mod so bad but ended up getting the covers from nigel because of the price nice write up..
yep PM me or email me rjrios@mail.usf.edu
