LED signal mirror cover?
Subscribe
Jan 31, 2012 | 04:15 PM
  #46
Quote: I figured it out... Finally grew a pair and tapped the wires... took me like three tries per wire... but got it done!!
The only wires visible are the obviously the LED covers but you can only see them if you remove the door sill. Everything else, was a *****... had to remove the speakers on both doors to easily access the rubber tubes from the door to the main cabin... I will go out once it gets dark and shoot a video or something...
Glad you got it done, it's by no means an easy task.
Reply 0
Feb 14, 2012 | 11:09 PM
  #47
i have a much easier place to tap the wires you guys need for hooking these mirror leds up. I had to pay to access the toyota information system when I did my remote start install a few months back. When I do my install I will snap some pictures and post em up for yall. The wires I used are located right behind the switches for the headlamp washers and rear window shade, since that is where one of the main fuse boxes it at. It took me forever to locate the things in TIS.
Reply 0
Feb 15, 2012 | 12:38 PM
  #48
B16da9 hey how much can I compensate you to me to help me install the lights once I get them? I live in Tampa
Reply 0
Feb 15, 2012 | 02:13 PM
  #49
you dont need to remove the speakers to feed the wire in the tubes, i found that to be easy the hardest part is running the wire from the fender to the inside of the car...i did 2009 mirrors though.
Reply 0
Feb 15, 2012 | 06:15 PM
  #50
Quote: i have a much easier place to tap the wires you guys need for hooking these mirror leds up. I had to pay to access the toyota information system when I did my remote start install a few months back. When I do my install I will snap some pictures and post em up for yall. The wires I used are located right behind the switches for the headlamp washers and rear window shade, since that is where one of the main fuse boxes it at. It took me forever to locate the things in TIS.
Please keep us updated.
Reply 0
Apr 8, 2012 | 09:31 AM
  #51
sorry this took me a little longer than expected, but here is a link to my post where I have a pdf showing where to access the parking light wires
https://www.clublexus.com/forums/7145746-post17.html
Reply 0
Subscribe
