hearing grinding sound when making sharp left turn
especially pulling into parking spots on the left side with modest speed. it sounds like something's rubbing or grinding underneath the car. i'm running f-sport springs and 19'' f-sport wheels, so i don't think it's the tire rubbing. any ideas?
The exact same thing happened in my other car. I would have to turn in going at least 30mph and I would hear a grinding when turning left. It wasn't a particularly expensive repair either, a tech should be able to spot it very quickly if it is in fact a bad bearing.
it might also be a CV joint--those tend to start grinding if the boot is torn and the grease has dried up--easy to fix but do it quick, too long and you will have to replace the whole CV joint instead of just repack the grease and the torn boot.
i just hope it's not cause by the 19'' f sport wheels i just put on. tires are all factory recommended sizes and i'm riding on f-sports springs so tire rubbing shouldn't be an issue. but the noise did start occurring recently just around the time i made the wheel swap.
i would pull the wheel, either you will have the tell tale scrapes on the lip of the wheel or a scorch, rubbing area on the tires.
if it's rubbing then why is it i only hear it when doing a left turn with a little speed. i don't hear a thing when doing it with parking lot speed.
apparently my tires are rubbing the plastic
when i got out the car it was not rubbing
but there's not even a finger gap wide of the place of the rubbing
so I suppose its the weight of the driver added onto the car making it rub
So I went to an empty parking lot and stopped when its making the sound
i'm pretty sure it's tire rubbing after seeing this thread:
https://www.clublexus.com/forums/sus...t-and-19s.html
if that's the case, is there a fix?
iceache925
Jun 5, 2021 08:06 AM
stlgrym3
Nov 4, 2011 09:31 AM
