What would you do? (GFX kit / Sway bar?)
Old 10-23-11, 11:24 AM
Vroomin350
Vroomin350's Avatar
I am gonna have to play devils advocate here and say GFX rear and side. The front sway bar only accounts for 6% stiffness, while the rear is already giving you the most change you will feel.
You also said you don't like the GFX front and I agree. If you plan on getting any lip it WILL look funny if you have a front lip and a rear but no sides. I was in that predicament once. The GFX sides can be appreciated in person.
GL
EDIT: saw your reference to the price of the sides, too much.. Get something else.
Old 10-23-11, 12:32 PM
dorkacho
dorkacho's Avatar
What does sway bar give you? Appearance or performance... ?
Old 10-23-11, 12:39 PM
rookieIS
rookieIS's Avatar
^ it improves handling.
i would personally get the sway bars if you are not getting the front, it will look weird with the rear and sides GFX w/o the front lip.
Old 10-23-11, 12:50 PM
dorkacho
dorkacho's Avatar
Like helps when your turn ? Can you actually feel the diff?
Old 10-23-11, 01:12 PM
Sango
Sango's Avatar
Unless one is going to track the car, the difference is can be neglectble for your general driving purposes.
Old 10-23-11, 04:32 PM
dorkacho
dorkacho's Avatar
I see. I probably will not need it then
Old 10-23-11, 04:46 PM
GiantsFan
GiantsFan's Avatar
Do you know what a sway bar is? Its under your car - part of the suspension!!! LOL
Yes, sway bar reduces body roll. IMO - it makes a big difference.
Thats up to you...
Old 10-23-11, 04:50 PM
Vroomin350
Vroomin350's Avatar
He already has the rear sway. IMO the front sway bar is a waste of money.
Old 10-23-11, 04:52 PM
GiantsFan
GiantsFan's Avatar
Well .... at least on the 250 - the front does make a big difference. Even if you have a 350, why not? Lexus designed the sways to be used as a pair...
Old 10-23-11, 04:55 PM
Vroomin350
Vroomin350's Avatar
True. I did forget that on the 250 it is a huge difference. As GiantsFan said, if you have a 250 the sway is worth it.
Old 10-23-11, 04:58 PM
WIZARD1325
WIZARD1325's Avatar
Sways
I say
Old 10-23-11, 05:19 PM
mong
mong's Avatar
I have a 350 and the 250/350 shared the same suspensions. The 6% information you guys got was a typo I think. Last time I checked lexus updated the front to 66% or 44% stiffer than oem front sway.
Old 10-23-11, 07:03 PM
Sango
Sango's Avatar
Here are the numbers from Lexus.com/performance, depending on the car.
IS250: 46.6% front, 6.3% rear
IS250 AWD: 65% front, 188% rear
IS350: 42.8% front, 151.5% rear
IS350 AWD: ???? (not listed!!)
Old 10-23-11, 07:07 PM
Vroomin350
Vroomin350's Avatar
^^ still correct, no typo. And the 350 and 250 do not share all suspension components, the 350's shocks are Tokico.
Edit: nice, the front sway is definitely worth it for the 350, might just have to get one then.
Old 10-23-11, 08:16 PM
Sango
Sango's Avatar
If X-Package suspension/Sport suspension on the 250/350, then both uses the same Tokico except for the front springs for 250/350 respectfully.
Quick Reply: What would you do? (GFX kit / Sway bar?)
