Shave rear fender liner bolts to fit LC818s????
Old 10-08-11, 05:32 PM
YoNadz
YoNadz's Avatar
Default Shave rear fender liner bolts to fit LC818s????
Lowered my car on Megan EZs today. Noticed that those little inner fender liner bolts stick out awfully far. I don't have my LC818s yet (should be here by the end of the month) but I'm curious if anyone had to shave these down to avoid damaging tires??? it appears that they are going to be really close once the 265s are on there.
Any insight appreciated. Thanks!
Old 10-10-11, 01:58 PM
YoNadz
YoNadz's Avatar
bump bump bump.
Old 10-10-11, 02:09 PM
600rr05
600rr05's Avatar
Im also running a 265/30 rear tire and didn't cut or shave anything but try sending Mv350 a PM he is the expert he was tucking tire on his IS.
Old 10-10-11, 02:43 PM
650IS350
650IS350's Avatar
Im running 275s and had the rear fender cut.
Old 10-10-11, 02:56 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I had 275/30/19 before with rolled quarter panels. I saw yhat scary bolt too. No problems. I have 255/30/20 now and I'm even lower. No problem still and I'm tucking rim!
Old 10-10-11, 08:37 PM
YoNadz
YoNadz's Avatar
Awesome. Thanks for the input. I guess I won't worry about it unless I run into a problem.
Old 10-10-11, 08:49 PM
whitebeast
whitebeast's Avatar
I'm running 265/30/19 with 15mm spacer and didn't have any problem so far. Still have some grap between tire and fender.
Old 10-11-11, 07:55 AM
YoNadz
YoNadz's Avatar
do you have LC818s?
mindf
01-13-16 03:42 PM
Jaytea
04-10-14 09:10 AM
ltzSupra
06-11-11 08:19 AM
SNiiP3R
03-01-10 04:44 PM
Quick Reply: Shave rear fender liner bolts to fit LC818s????
