Success: Installed an IS300 Torsen LSD in my IS250
#122
I’ve done similar tool making. Why go and buy an expensive tool for one time use. I’ve bought so many tools that I’ve used once. Or never used. I was diagnosing a vacuum leak couldn’t find it so I ordered a $1800 smoke machine. Found the leak befor it came in and haven’t used the smoke machine yet.
#123
A press is nothing more than a rigid frame and a bottle jack. Everything needed was already sitting in my garage, so I used what I had. I really like to work steel, been a two hours built and it worked great. These, more than 1/4" inch, L bar doesn't flex at all.
#125
The IS250 uses either a 180mm or 205mm differential. The IS300 uses a 205mm differential. The IS200d, IS220d and IS350 use a 208mm differential.
The options vary between them, what is being discussed in this thread specifically is the 205mm differential used in IS250 RWD and 2009+ IS250 AWD models.
Are you looking for an LSD for an IS250 or for an IS220d?
Jeff
Jeff
#126
Jeff
Jeff
The is200 lsd will fit the is250 but I think you need some kind of an adapter?
#127
The Mark 2/Verossa/IS200/RS200 (GX110/GX115/JZX110 - 1JZ-FSE models/JZX115/GXE10/SXE10) use a 180mm differential. The LSD from this can be used in the 06-08 IS250 AWD.
The Mark 2/Verossa/IS300/FR-S/86/GT86/BRZ (JZX110 - 1JZ-GTE models/JCE10/ZN6/ZC6) use a 205mm differential. The LSD from this can be used in the 06-15 IS250 RWD and 09-15 IS250 AWD.
The LS460/IS350/IS F/RC200t/RC300/RC350/RC F/GS200t/GS300/GS300h/GS350/GS F (USF40/GSE31/USE20/ASC10/GSC10/USC10/ARL10/AWL10/GRL12/URL10) use a 208mm differential. The LSD from this can be used in the 06-12 IS200d, IS220d, 06-19 IS350, 16-19 IS200t, and IS300.
No adapters are needed for any of these options. Note that the gear ratios may or may not be correct for what your application is. If it is not correct, you will need to swap the gear set.
Jeff
Jeff
The following 2 users liked this post by Jeff Lange:
Allan1 (03-08-19),
redspencer (03-08-19)
#128
Thanks Jeff. After owning my Lexus IS250 for three years and searching the junk yards, I finally got my hand on a Torsen lsd (M98) for cheap. Your insight was really helpful.
Jeff Lange (08-14-20)
#129
07 Is 250 AWD TAPPIN NOISE
I got priced at $842 for a rear differential right side axle work. The tapping noise is right at the rear passenger wheel right where the wheel connects to axle u can hear the friction each rotation. Is that too high for just one side n a new differential. This guy charged me $442 for 2 new rear rotors n brakes( he changed parking brake too) n thought that would be the fix. Who has experience changing is250 rear diff or axles. Accurate info appreciated
#130
Thanks to the author for the information, read and learned a lot of interesting things, I personally just took the differential from GT86/FRS/BRZ I put it on and I am very happy it became
#132
There is not only a subframe, there still needs to be redone the cardan and drives from 2.5
#133
To your point, if one removes the propshaft nut and flange, a new crush sleeve is needed behind the seal and front bearing.
#135
