Changing the headlight bulb
Old Aug 8, 2011 | 10:04 AM
khuezee's Avatar
khuezee
Default Changing the headlight bulb
Is there a DIY? I can't seem to find it anywhere. Also did a google search and it comes out with changing the ballast(which I don't think is necessary). I really hope you don't have to take apart the bumper and the entire headlight to access a simple bulb. Can some point me in the right direction? Thanks again.
Old Aug 8, 2011 | 10:24 AM
felixsc300's Avatar
felixsc300
No need to dismantle your front to change bulb - its accessible from the engine compartment. IIRC just remove the airbox on the passenger side and the windshield wiper fluid tube on the driver's side (or the other way around) to give you more room to work with. Both can be removed with a simple 10mm wrench.
Old Aug 8, 2011 | 12:47 PM
brociouz's Avatar
brociouz
^ Yup. You can follow a DIY on how to change parking lights if that's not enough info. The low beams have a side entry design so the low beam moisture shield will be at a 90 degree angle to the parking light/DRL/high beam moisture shield. It'll be pretty obvious once you take a look.
Old Aug 8, 2011 | 04:06 PM
T4styPh0's Avatar
T4styPh0
The DIY thread on changing that, hope its helpful
https://www.clublexus.com/forums/is-...hid-bulbs.html
peppertree
Oct 28, 2019 11:17 AM
Oro
Mar 8, 2015 06:17 AM
kamj2210
Jan 20, 2013 09:52 AM
poley1
Feb 20, 2011 04:44 PM
LilMan23
Nov 20, 2009 09:02 AM
