TPMS Hardware?
Most Lexus dealers (at least in Canada) should be able to read the TPMS codes without dismounting the wheels as well, as there is an SST to do just that, and then use the Techstream to program them to the car. The aftermarket programmers can do both, usually.
Jeff
Those are the TPMS I bought on ebay.
My car only has ONE TPMS installed in the OEM wheels now (don't know why PO removed three of them)
anyways, I stopped by Toyota assuming I needed to buy some hardware. The hardware they had was $12 per wheel and it looked like a metal sleeve and two washers (one metal and one rubber) - that look to be already on the sensor.
What do I need to buy to mount these in the rims when my new tires go on tomorrow?
TIA!
Can these sensors be of different part #? I was given #42607-33030 and Sewell has #42607-30030. The #'s on ebay (42607-33021/11) do not match these other numbers. According to my local dealer, I must use the exact part number that matches my bin # or sensors may not work. I really don't want to take a chance. I hear different versions but I want to hear it from someone that has really opted to buy from ebay and has taken them to be programmed at dealer.
TIA
Can you post pictures of all items you will be using to get these sensors installed (e.g. sensors part #, washers etc.) and can you also let us know once the installation is complete and lights are off your board.
I know dealers discourage people from buying aftermarket products because they want to make the big bucks, but it these parts work we do not have to buy from dealer.
Also provie vendor and price
I will appreciate your info.
Have you solved your problem yet?
Any lights still on for your TPMS?
Where did you finally take it?
Did your dealer people give you any hassle because they were aftermarket or bought off ebay?
Please any help will be greatly apprecated
