IS350 CEL/MIL/VSC problem
Old Feb 22, 2026 | 01:23 PM
Justincontre's Avatar
Justincontre
7th Gear
Hello,
i hope someone could help me with this issue im having. Im getting a misfire in cyl 1 its usually when im downshifting at a light or a turn.
other than that the car runs great and idles great.
my fuel trims are the following at idle: Short Term Fuel Trim - Bank 1
0.0 %
Long Term Fuel Trim - Bank 1
9.4 %
Short Term Fuel Trim - Bank 2
0.0 %
Long Term Fuel Trim - Bank 2
19.5 %
when driving the LTFT Bank 2 drops to around 7%
but when idling its very high. First things i did was check for vacuum leaks everywhere but found none (using smoke machine)
new spark plugs and switched coil pack from 1 to 3
but still is the same code P0301
i have checked the wiring connector for the injectors and ohmed out the injectors to 14.3 and 14.6 on 1 and 3 (still havent checked others)
i dont know what to move forward with. I was thinking maybe a clogged injector in cyl 1 but unsure
vmichelle
Apr 15, 2024 01:34 PM
is250fsprt
Sep 25, 2019 12:52 PM
red13
RX - 1st Gen (1999-2003)
17
Oct 27, 2011 07:54 AM
pitmanr200
Aug 9, 2008 09:27 PM
joshoowa
Dec 14, 2005 07:15 PM
