IS 350 in the winter
http://varrstoen.com/blog/
Steelies that'll clear brakes on a 350 might be hard. You're pretty much going to have to buy alloys. Canadian Tire has some super cheap ones. But don't forget, you need TPMS sensors for each wheel. Which are $100/each. Running a separate set for winter is expensive, but I'm super glad I have it.
I'll check Canadian tire and see what they got for alloy wheels thanks. I forgot about them.
If you are getting steelies, might as well get the Varrstoen ES 2.2.2., $700 per set and it's ISX50 fitment. I have a set of these on my TSX, 19x8.5 all around, each wheel weighs just under 24 lbs each. They come in different finishes and the standard colour is matte black.
Thanks but I'm looking for 17s because that's the size of tires I ordered. 225/45/17 all around is what I'm getting.
If I can't find any inexpensive wheels for winter then I'm just gonna swap to my current stockies if it comes down to it then perhaps buy some nice aftermarket wheels for summer haha
Yeah I'm having a hard time finding some that'll fit on the car. I'm gonna do without the TPMS seeing how it's just gonna be for winter and I don't think it'll be worth the extra $$$.
I used to live in MTL and I know that changing a tire with no impact gun at -30C is the worst thing in the world. It'll cost you a few bucks to swap the sensors out, but the one day it saves you, you'll be thankful you did. Just my two cents. Also, check out 1010tires.ca. It's a Canadian site so no brokerage/duties to pay and no PST/HST for out of province. We get just devastated on shipping costs here, so you might be able so snag a deal on there. Let me know what you come up with for your solution!
Can someone pls tell me what the Bolt pattern specs are?
And what kind of wheels(rims) would you guys suggest for winter tires? not too pricy..
I asked my friend that works at a local tire shop around where I live and they said they don't have any steelies that will fit my car.. I don't believe this because I've seen other IS's around the city with steelies.
I just bought winter tires but have no rims for them... any help appreciated!
call around and see what you can find. I think I paid less than $100 per rim and they are 18x8's
If I'm honest with you, I'd put your TPMS in your winters, not your summers. Running low in winter is far worse than in summer due to the air pressure being lower in your tires due to the cold causing premature failure. I'd rather change a flat in the summer than the winter. I know there's snow from time to time down east
As for the rims, I went to my local Kal-Tire and bought a set of CoreRacing aluminum rims for around $600 with tuner lugs. These rims were the cheapest I could find that would fit the car.
Tire spec: 225/45/17
Rim spec: 17x7, +40 offset
These tires have been great in the snow/ice since I've had them on my car
Well if last nights trip home wasn't an awakening for snows I don't know what is. Not too many issues on the expressway but I barely made it up the un-plowed exit ramp. There was a lot of sliding and feathering of the pedal. I really thought is was going to get stuck at one point. Had the snow button and traction on, only 1/8th tank of gas and an empty trunk.
newToIs250
Mar 9, 2016 11:49 AM
