is350 steering column does it move??
Old Oct 16, 2010 | 09:54 PM
wr332's Avatar
wr332
Default is350 steering column does it move??
on my rx350 everytime i insert the key to start the car the steering wheel will come out and up and then when i take the key out it will come down and go back in.
i wanted to know does is350 have this option?
i didn't notice it but it's not doing it on my 07 is350 ,
like this, when you put your key in and it comes to greet you..
example
http://www.youtube.com/watch?v=QWusu_L4cns
Old Oct 16, 2010 | 10:16 PM
wr332's Avatar
wr332
i attached a video of the example.
Old Oct 16, 2010 | 10:22 PM
Micaiah's Avatar
Micaiah
I believe if you have the power telescoping column it will do it.
laobo979's Avatar
laobo979
its an option if you have a base 350 you wont get it
Old Oct 16, 2010 | 10:30 PM
new.era.13's Avatar
new.era.13
you need that luxury package.
Old Oct 16, 2010 | 10:33 PM
Micaiah's Avatar
Micaiah
I don't have the luxury package, but rather the sport. I still have this feature somehow.
Old Oct 16, 2010 | 10:59 PM
wr332's Avatar
wr332
well i pretty sure i have it , i'l got the NAV it should be either sport or luxury. it stop moving after i got the car service and in the my lexus log it says that they reset my system.
Dealer Reported 10/16/2010 0152100 RESET SYSTEM SETTINGS
Old Oct 16, 2010 | 11:11 PM
quang's Avatar
quang
Do you have "power" telescoping column (the switch on the pic)? If you do, may be your power telescoping column is set to the highest and nearest to the dashboard so it does not move up and down.
Old Oct 16, 2010 | 11:16 PM
wr332's Avatar
wr332
car has memory seats and woodgrain , NAV, it's luxury package
Old Oct 16, 2010 | 11:36 PM
wr332's Avatar
wr332
my lexus tells me i got recalls, maybe they disable it to do the recall next week,,
2007 LEXUS IS350
Safety Recall ALE - Certain Lexus GS 350, GS 450h, GS 460, IS 350, LS 460, LS 460 L, and LS 600h L Vehicles - Valve Spring
This is an important Safety Recall. Please contact your authorized Lexus dealer and schedule an appointment to replace the valve springs with the newly designed ones as soon as possible.
What is the Condition? During the manufacturing process the valve springs on certain Lexus vehicles were contaminated with a foreign material. As a result, the strength of the spring might be compromised. Over time, there is a potential for the valve spring to develop a crack and eventually break. A broken valve spring may result in abnormal engine noise, vibration, and/or power reduction. In the worst case, the engine may stall or not accelerate as quickly as anticipated, which could result in a crash.
SSC 9LG - Potential Floor Mat Interference with Accelerator Pedal
This is an important Safety Recall to make it less likely that an unsecured or incompatible driver's floor mat can interfere with the accelerator pedal. Please contact your authorized dealer to have this remedy performed.
For additional information regarding our Pedal Entrapment Recall, click here.
Certain 2006 - 2007 GS, IS And RX400h Vehicles, Electric Power Steering Link (EPS) Assembly Replacement
This is an important Special Service Campaign. Please contact your authorized Lexus dealer to make an appointment to replace the electric power steering link (EPS) assembly as soon as possible.
Certain 2006 - 2007 GS, 2006 - 2008 IS And 2007 - 2008 LS Vehicles, Replacement Of Fuel Delivery Pipes (Fuel Rails)
This is an important Safety Recall. Please contact your authorized Lexus dealer to make an appointment to replace the fuel delivery pipes as soon as possible.
Certain 2006 - 2008 GS And IS Vehicles, Rear Brake Caliper Inspection
This is an important Service Campaign. Please contact your authorized Lexus dealer to make an appointment to inspect and lubricate the rear caliper slide pins as soon as possible.
Old Oct 17, 2010 | 07:50 AM
Kurtz's Avatar
Kurtz
Both the sport and luxury package (neither of which have anything to do with having navigation or not) have the power tilt/telescope steering wheel.
If you have memory seats you have this option, otherwise you do not. It's that simple.
Old Oct 17, 2010 | 09:14 AM
my95tsi's Avatar
my95tsi
wr322 it's not rocket science. Does your steering wheel have the power button and the left hand side of the steering column? If it does then you just need to adjust it and program it into your programmable settings on the door. Once you program it will do all the fancy moves you a looking for. If you don't have the power button on the steering column then no one can help you as you don't have that option.
Old Oct 17, 2010 | 06:39 PM
Micaiah's Avatar
Micaiah
Ah this makes sense. Because when you do the memory doesn't that adjust the steering wheel as well?
Old Oct 18, 2010 | 05:10 AM
Kurtz's Avatar
Kurtz
Yup... memory settings will adjust:
Seat settings
Side mirror settings
Steering wheel settings
stuttat
Build Threads
Aug 21, 2015 05:55 AM
sby123
Canada
Mar 9, 2015 07:13 AM
BOBFSPORT
Nov 15, 2014 09:06 PM
chiawei
Nov 7, 2005 03:01 PM
